stevei Lifetime Member
Posted: Thu Jan 19, 2006 11:10 pm Post subject: CheckPOInt 5.0 |
Just before i decide to install checkPOInt 5.0 . Can anyone tell tell me if it detects the speed cameras with the POIs hidden. _________________ Steve I |
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Fri Jan 20, 2006 8:09 pm Post subject: |
Hi stevei
I cant remember off hand whether checkpoint works with the points of interest turned off. However, I have a feeling that it does. There is one thing that I do know for sure and that is that it’s a brilliant add-on to TT5. If you aren’t sure that its for you, then make a proper backup before you install it. _________________ Tomtom Go 720.
Navcore 9.510
Central and Western Europe v855.2884
GPS World Traffic cameras
Home 2.7
iPhone 3G |
Maverickuk Occasional Visitor
Posted: Fri Jan 20, 2006 10:11 pm Post subject: |
Whats the advantage of using Checkpoint over the standard POI announcement in TT ?
Mav |
peterc10 Frequent Visitor
Posted: Fri Jan 20, 2006 10:16 pm Post subject: |
Don't know about Checkpoint but certainly Tom Tom itself will still warn if you have POIs hidden |
Posted: Fri Jan 20, 2006 10:34 pm Post subject: |
Maverickuk
The advantage of checkPOInt over the embedded warning is that it gives two wawarnings at different distances, warns you if you are overspeed and is easier to add voices rather than bells or noises, and it is free.
I decided to install it anyway and it still works with the POIs hidden. Very dissaPOInted with the buggy flashing display, it does warn you about the possibility and hopefully will be fixed in a later release. _________________ Steve I |
Posted: Fri Jan 20, 2006 10:48 pm Post subject: |
Yes stevei I forgot to tell you about the flashing display. It bother some people and others ignore it. If you turn on checkpoint and click General Settings you will come up with a screen showing three items. If you take the tick out of the ‘Show Warning Information’ box you will get rid of that annoying flashing. Give it a try. _________________ Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G |
Posted: Fri Jan 20, 2006 11:01 pm Post subject: |
Trevor1234
In the manual it refers to a tab for repeating the warning every ??? secs. on "section cameras" (specs). I cant see this tab on any overlay settings. Do you know how to display this feature? _________________ Steve I |
Posted: Sat Jan 21, 2006 12:09 am Post subject: |
Hi stevei
Go to Overlay Settings, Tap on Traffic Cameras, Tap on Section Cameras, Tap 40 (just as an example) so that it highlights the words ‘Section Camera 40’ and then tap on Properties and the screen that then comes up First Warning, second warning etc. This also applies with all cameras. See how you get on. _________________ Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G |
Posted: Sat Jan 21, 2006 7:49 pm Post subject: |
stevei wrote: | The advantage of checkPOInt over the embedded warning is that it gives two wawarnings . |
Cheers Steve might give it a go.
Mav |
Posted: Sat Jan 21, 2006 8:35 pm Post subject: |
stevei wrote: | Maverickuk
The advantage of checkPOInt over the embedded warning is that it gives two warnings at different distances, warns you if you are over speed and is easier to add voices rather than bells or noises, and it is free. | You can still do this with the inbuilt TomTom system, but it does consume a lot of user avail POI's,
First install the speed camera zoned POI's then load up the single file version, you will need two copies of red-light and Temp for this to work (re-name the files adding something like _2 to the end of the file name NOT the file extension).
For proper warnings I use www.tomtomsatnav.info and the POIExtend utility to increase the number of inbuilt warnings from 15 to 30, this also gives you the option for proper spoken alerts containing the camera type and speed zone where applicable (there are also voices avail from the same site to do this) more importantly it gets rid of the allocated title for each warning, allowing you to make meaningful names for each of the warnings (This alone makes configuring the next bit so much easier).
Then set-up the TomTom Warn when near POI for each camera set, but for the second warning use the single file version OV2 and drop the warning distance to closer to the camera. You get a double warning, no flashing but unfortunatly no continual SPECS speed warning, this will also re-name some of your custom voices (if installed) but this is a minor price to pay -
It works great on my set-up - hope some of you can follow this alternate way to get the same result - Mike |
Posted: Sat Jan 21, 2006 9:18 pm Post subject: |
Trevor1234 wrote: | Go to Overlay Settings, Tap on Traffic Cameras, Tap on Section Cameras |
In Overlay Settings i have one directory "Not Synchronized", this expands to show all the diffent types of cameras ie "pocketgps_uk_gatso" etc.
What am i doing wrong? _________________ Steve I |
Posted: Sat Jan 21, 2006 11:10 pm Post subject: |
Hi Stevei
I know that you have installed checkpoint but have you connected to the website and synchronised? You can not proceed until you have done that. _________________ Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G |
Posted: Sat Jan 21, 2006 11:47 pm Post subject: |
Thanks for the help Trevor1234
OK now synced up and got section cameras. All appears OK
Do these overlays sync with the pocket gps cameras that i have setup. _________________ Steve I |
Posted: Sun Jan 22, 2006 3:06 pm Post subject: |
Hi stevei
Once you have set up the checkpoint cameras that you want to use (by putting a tick in the relevant boxes) every time you connect to the checkpoint website and synchronize it will update the type of cameras that you have selected. New ones are added and some are deleted depending on what’s taking place out on our streets. Make sure you only use the cameras and speed settings that you want to use and make sure that you have United Kingdom checked before doing so. Checkpoint has lots of cameras, restaurants, hotels, fast food joints etc but the more you install the slower your PDA may run. So don’t get carried away. _________________ Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G |
Posted: Sun Jan 22, 2006 3:17 pm Post subject: |
Thanks Trevor1234 worked it all out last night. I have just opened a new topic about the viability of the Pocket GPS or CheckPOInt database, perhaps i can have your oppinion. _________________ Steve I |
