treborvfr Occasional Visitor
Posted: Fri Jan 13, 2006 1:01 am Post subject: Which GPS Receiver for iPAQ 2210 and TT5? |
At the moment I run TT5 with an iPAQ 2210 and a Globalsat BC307 GPS Rx.
Since upgrading to TT5 I have never been very happy with the sensitivity of the set up, I always seem to acquire less satellites than I did when using TT3 (I am using the latest patch for TT5) and loose the signal regularly whereas with TT3 very rarely did.
On occasions, with TT5 on loosing the signal, I loose the fix completely and it can take ages before a fix is obtained again.
I believe that the drivers with TT5 result in the GPS performing with much less sensitivity than with TT3.
Of late I think the problem with sensitivity has worsened, possibly the BC307 failing? This, together with another fresh problem of TT5 locking up resulting in a soft reset to get it back, makes me tempted to revert to TT3 and see if things improve.
That said, there is a temptation to try one of the latest, more sensitive GPS Receivers. I like the convenience of a Compact Flash GPS being powered from the iPAQ so only one power source required (I use it mainly on my motorcycle so prefer to travel light, the fewer chargers the better!). However, I am keeping an open mind and could sway to a Bluetooth GPS, probably the Globalsat BT338 or the Holux BT236. Trouble is I've heard that Bluetooth devices can be a problem with an iPAQ 2210 with the Bluetooth signal dropping out when on the move and becoming unuseable.
So, I'd like to hear comments from those that use the iPAQ 2210 (or 2215) with TT5 and Bluetoooth GPS particularly Globalsat BT338 and Holux BT236 please.
Any pros and cons with either BT Rx?
Are things likely to improve and would the upgrade be worth it?
What about Compact Flash GPS receivers?
All comments gratefully received.
Bob |
ttrevor Lifetime Member
Joined: Dec 04, 2003 Posts: 540 Location: Sleaford Lincolnshire UK
Posted: Fri Jan 13, 2006 10:35 am Post subject: |
I use a Holux 236 BT and its brilliant ,no drop outs of signal ,sits in the glovebox of my car never loose a signal easy to set up ,so i can not fault the 236 well worth the money :D _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
astrocompass Lifetime Member
Joined: Aug 15, 2005 Posts: 156 Location: Windsor, UK
Posted: Fri Jan 13, 2006 10:36 am Post subject: |
Bob
Quote: | Trouble is I've heard that Bluetooth devices can be a problem with an iPAQ 2210 with the Bluetooth signal dropping out when on the move and becoming unuseable. |
News to me. Never had a problem - 338 works fine from the glovebox & under the seat - should be fine from a jacket pocket if you're on a bike. Lasts for ages on one charge.
Trouble with CF GPS is fiddling around swapping cards in and out - plus how to protect the 2210 and CF on a bike.
Personally I'd stick with BT - Holux or Globalsat, both seem well received. _________________ Garmin 2360LT
iPaq 2210 TTN5.2 |
alix776 Pocket GPS Moderator
Posted: Fri Jan 13, 2006 11:54 am Post subject: |
from what I remember the bluetooth issue was down to the sd card reader which was not reading the card fast enough usually this was solved by using a cf card that said we havent had any issues of this latlely on the site with the 2110 so I think that hp solved the problem this didn't affect all 2210's have you tried takeing a back up of the sd card and then formating the sd card I know my own 2210 runs fine as does a few friends ipaq's _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
ROBBINS Regular Visitor
Joined: Dec 04, 2003 Posts: 82 Location: Worcestershire
Posted: Fri Jan 13, 2006 12:53 pm Post subject: |
Yes you need to run the 2210 with a good CF card - try valueflash for good prices.
Robbins |
Posted: Fri Jan 13, 2006 1:36 pm Post subject: |
I don't use a CF with the 2210, just a 1GB SD card, never had any problems before when using TT3 with these cards, only have the maps and some music stored on them.
To everyone else, thanks for the comments so far, it looks like gewtting a decent BT GPS is the way to go.
Bob |
Joined: 30/12/2002 17:36:20 Posts: 4912 Location: Oxfordshire, England, UK
Posted: Fri Jan 13, 2006 1:40 pm Post subject: |
Hi treborvfr,
Using an SD card with a BT receiver on an iPAQ h2210 caused the Bluetooth problem.
I run TomTom Navigator 5 on an iPAQ h2210, with a Kingston 1024Mb CF card (bought from valueflash), and a GlobalSat BT-338. The whole set-up is stable and the BT-338 is a fantastic GPS receiver.
Garmin Camper 770 LMT-D |
Posted: Fri Jan 13, 2006 3:13 pm Post subject: |
Privateer wrote: | Hi treborvfr,
Oh dear, I've not that long since bought the 1GB SD card, I know they are not that expensive these days but it seems that to get TT5 to work properly I have to throw more money at the set up
I think I may just revert to TT3 ,
at least it all worked then, and at a later date just go and buy a proper GPS such as a Garmin.
Bob |
Posted: Fri Jan 13, 2006 6:46 pm Post subject: |
Well ive used a SD card for my 2210 for running TT5 and have not had any trouble at all :D _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Fri Jan 13, 2006 7:42 pm Post subject: |
Hi treborvfr
I can assure you that the BT338 and the Ipaq 2210 work together perfectly. Its gets a fix from cold in seconds and wont loose it even when driving down streets surrounded by high buildings. I can honestly say that since I have run TT5 and the BT338 the program has never froze, never lost its signal or let me down in any shape or form. I should add that I use in the UK and on the continent where it also performs without mishap. I wouldn’t dream of going back to TT3 _________________ Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G |
Posted: Mon Jan 16, 2006 3:20 pm Post subject: |
Thanks all for your input.
I must say I'm torn between getting a BT-338 (and making my existing system work as it should) and buying a Garmin 2610.
Time to check out some prices I think.
Bob |
tenminnit Occasional Visitor
Posted: Wed Jan 18, 2006 6:52 pm Post subject: |
I need help please
I have a HP Ipaq 2210 with 1.10 bios and have successfully used it with TomTom 5 with infra red connection for GPS with a universal car mount.
I now need portability between a number of different cars.
A bluetooth receiver is the answer for me having loaned a pal's cheap bluetooth GPS receiver set up via NMEA option at 9600 baud through bluetooth com 8 in TomTom - it works well
I decided to go better! I have bought a Holux 236 - configured it as above as the recommendation at www.holux.com FAQ.
The symbol at the top RH corner revolved but gives the message 'No GPS Device' on configuration. When a route is planned gives the message 'Waiting for a valid GPS'
Is the Holux faulty? |
Posted: Wed Feb 15, 2006 11:45 am Post subject: |
Thanks again for your help with this, I finally opted to go for a Globalsat BT338 and should be getting it in a few days.
So just another question if you don't mind.
What is the best way to set it up with a iPAQ 2210 and TT5, do you just set it up has 'Other Bluetooth GPS', or 'Other NMEA GPS' with baud rate 38400 and Bluetooth Serial Port Com 5 or 8 ?
Bob |
