Pocket GPS World :: View topic - tt nav5 glitch
tt nav5 glitch
rsvdaz
PostPosted: Fri Jan 13, 2006 7:08 pm    Post subject: tt nav5 glitch Reply with quote
hi all,
I'm running tomtom navigator 5 on my XDA IIi with Arkon CM845 gps receiver, I updated the software via down load on the tomtom site..it has now developed a glitch where everytime i get a voice direction or noise warning the screen freezes for 5 seconds then says no gps device for another 5 seconds and then is ok. I contacted tomtom and ther say re-install via CD..trouble is the CD only has the user manual and the software was pre-installed on a SD card..can anyone offer me any further advice?
PostPosted: Fri Jan 13, 2006 8:25 pm    Post subject: Reply with quote
Hi ravdaz, welcome on board.
I can't answer your question, but could I ask you not to double post. It is very difficult to follow the thread if there answers all over the place.
I have deleted your other posting.
PostPosted: Fri Jan 13, 2006 8:30 pm    Post subject: Reply with quote
Have you got a load of POI enabled on the unit? if so de-select them and try it again, see if that improves the situation, use the warn when near POI option to still show the cameras - Mike
rsvdaz
PostPosted: Sun Jan 15, 2006 11:22 am    Post subject: Reply with quote
sorry Richard Embarassed I posted first in the Beginners section then came across a more specific section
Ive done this and its still the same Confused ...Is there a way I can roll back the upgrade..as it was working fine before.........unfortunatly I didnt back up the SD card Embarassed
alix776
PostPosted: Sun Jan 15, 2006 6:09 pm    Post subject: Reply with quote
try deleteing tomtom softreset then reinstall 5.2
device Lumia 950 xl
rsvdaz
PostPosted: Sun Jan 15, 2006 7:56 pm    Post subject: Reply with quote
tried this also...i think the tomtom site upgrade overwrote whats on the SD card...like a fool i didnt back up the card before installing Embarassed
alix776
PostPosted: Mon Jan 16, 2006 12:34 am    Post subject: Reply with quote
have you tried formatting you sd card i have a similar set up on an xda2i and holux cr100 that is used for work even during a call its fine and runs smoothly
device Lumia 950 xl
rsvdaz
PostPosted: Mon Jan 16, 2006 10:06 am    Post subject: Reply with quote
wont formatting the SD card lose whatever is on there (ie TTN5)?
rsvdaz
PostPosted: Tue Jan 17, 2006 2:01 pm    Post subject: Reply with quote
still not resolved this glitch...although tried a re-install...hard restart etc...i didnt back up the sd card before upgrading off the tomtom site..and there support is useless Crying or Very sad this is a legit version....and now have aquired a copy by a.n.other i have installed this as yet...would prefer to get the one i paid for working...but....if i did install it...what are the consequences?...i mean i own a licence for it afterall?
Terence-TJ
PostPosted: Fri Jan 20, 2006 2:09 am    Post subject: Reply with quote
I had the same problem and found, as already suggested, a complete re-install on the same SD card nearly helped - the problem was due to the Voices and POI files - there were too many. The final soultion was to use an SD card larger then the supplied 128MB, 256MB should be ample. Once everything was on the new card it works perfect.
On the backup front (I use a Treo 650) I always backup to the [new] TomTom card as I still get the error relating to lack of memory after installing more POI's. Once backed-up and restored all functionality returns. Smile
Trevor1234
PostPosted: Fri Jan 20, 2006 6:03 pm    Post subject: Reply with quote
Hi rsvdaz
Oh dear! What a cock-up. Never mind, you have learnt a valuable lesson and will no doubt always make a backup in the future before carrying out alterations to your PDA or card. However, if you purchased a legitimate TT5 version then you must contact Tomtom however time consuming that may be. It will all come right in the end.
Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G
rsvdaz
PostPosted: Tue Jan 24, 2006 2:09 pm    Post subject: Reply with quote
ok..i now obtained a back up and a 256mb card...i still have the same problem????!!?!?!?!?!?!
only this time it onbly locks up when it says it cant detect a gps device...still for about 5 seconds.
now wondering if its the gps device?
Arkon CM845 powered gps mount Crying or Very sad
PostPosted: Tue Jan 24, 2006 6:46 pm    Post subject: Reply with quote
Since you performed the hard reset have you de-selected the receive all beams check box in Settings/ Connection tab - IRdA, if not there will be no data flow to the PDA via the serial port - Mike
22.062 (12 Jun 24)
