helen123 Occasional Visitor
Posted: Fri Jan 13, 2006 3:41 am Post subject: tomtom navigator 5 preloaded software and map on sd card |
1st question-if i buy the tomtom navigator 5 on a preloaded sd card can i transfer it to a 1g sd card and also put other mp3, jpg file onto the card without affect tomtom? if the asnwer is yes,
2nd question- how about putting other .exe files in, such as games...?
thanks... |
Posted: Fri Jan 13, 2006 9:50 am Post subject: |
Helen, Welcome to the forum, the answer is yes to both your questions - Mike |
Posted: Fri Jan 13, 2006 4:57 pm Post subject: |
thanks, but having a few .exe files, wouldn't that affect the pda? i mean, wouldn't as soon i as insert the sd card, the pda will load it? hmm...thanks in advance:) |
Posted: Fri Jan 13, 2006 5:03 pm Post subject: |
Not unless the file is of a certain type, the TomTom card has an auto installer, but alot of other applications are loaded in a different way on the PDA, so the files can co-locate on the same card, although to keep it all tidy I usually put the files into respective folders (where possible) - Mike |
Posted: Fri Jan 13, 2006 6:39 pm Post subject: |
what do you mean respective file? doesn;t the tomtom files need to be in the root directory? just i will need to create for example two folder in the root directory, one for mp3 and one for games....? and then store files in those folders? i think you mean don't place many single files in the root directory, right? cheers |
Posted: Fri Jan 13, 2006 8:15 pm Post subject: |
Helen, the tomtom files on the SD card reside in specific folders, if you add mp3 file etc then you can put them where you want even in the root of the card and it will make no difference, I only sugested using folders as it makes finding files easier later on. I have a number of applications on the SD card, loads of mp3 and a DVD movie ripped down to play on the PDA, I experiance no problems with this set-up in use. I have a folder named mp3 containing further folders with artists names on them, in here reside the applicable tracks and another named DVD in the root of the card - Mike |
