Bluefonze Occasional Visitor
Posted: Fri Jan 13, 2006 2:11 am Post subject: GO 700 PROBLEM |
My go 700 has started to take absolute ages for it to load up, it used to take roughly 30 secs to start up but now can take a good 10 mins. would be grateful of any suggestions. |
JLee Regular Visitor
Joined: Dec 11, 2005 Posts: 139 Location: Barnsley UK
Posted: Fri Jan 13, 2006 10:00 am Post subject: |
What changes have you made recently? Do you have a backup you can try? |
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Fri Jan 13, 2006 11:47 am Post subject: |
Try a reset first. Poke an unbent paperclip into the reset hole underneath. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Fri Jan 13, 2006 2:05 pm Post subject: |
The only changes i have made is the recent version upgrade.
When the unit is loading there is a yellow progress bar that shows the progress as if the unit is booting up from fresh. 8O |
Posted: Fri Jan 13, 2006 3:06 pm Post subject: |
We can't help you unless you comment on what happened when you followed our suggestions? Did you try a reset? Do you have a back up you can try and go back to temporarily? |
Posted: Fri Jan 13, 2006 10:49 pm Post subject: |
I have tried resetting the Tomtom but has made no difference, I do have a back up but i don't know how to reinstate it.
Do I copy and paste the old files into the tomtom and replace existibg files?
Thanks in advance. |
Oldboy Pocket GPS Moderator
Posted: Sat Jan 14, 2006 9:58 am Post subject: |
It depends how you did the Backup.
If you used Copy/Paste to the PC you will need to Copy/Paste back to the SD Card to do a Restore/Reinstall.
If you used the Backup that comes as part of the TomTom Setup you will need to used the Restore Option on the same Setup Menu. _________________ Richard
Posted: Sun Jan 15, 2006 12:40 pm Post subject: |
I have tried restoring my back up (which was an older version 5.200) and everthing seemed fine, i have then updated back to the newest version, now the problem has returned. I have tried deleting my unused voices but it has made no difference. The problem only occurs when the tomtom has bean switched off for a few hours.
Is anyone else experiencing the same problem?
It also seams to take an age to fix on to the sattelites then once it has finally found the sattelites and i choose my destination, the map loads up very slowly.
Please help! ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
