Pocket GPS World :: View topic - Globalsat SD-502 Compatibility
corky
PostPosted: Sun Jan 01, 2006 4:45 pm    Post subject: Reply with quote
Well i think i found out why my map is so lagging while driving about, if i install the 102mb uk map onto my own mmc card it installs quite quick, about 8 - 10 mins. But when i install the same onto the sd-502 memory it takes nearly 30 mins !!
That may explain why i suffer sluggish map updates while driving about ?
Unless i can cure this i think i may have to send back the unit, oh well...
hacksawbob
PostPosted: Sun Jan 08, 2006 11:39 pm    Post subject: Reply with quote
thanks for your help guys but no joy, got a replacement sent and it didn't work either, so I'm giving up for the time being maybe get a Bluetooth device later. You never know it may be my phone but from what I can see the SD-502 is NOT compatible with the T-mobile MDA compact (imate-JAM). I did a hard reset of my device and tested with no tom tom software so this wouldnt have interfered, no satellite data was reported with globalsats own software (gpsinfo) even though the device was flashing blue to show it was communicating with the sattelites.
xda
PostPosted: Mon Jan 09, 2006 5:14 am    Post subject: Reply with quote
When you installed the SD-502 device driver and re-booted the PPC do you have a directory called GPSDisk Card showing. This is the new SD storage card.
If this is not showing on your PPC then you won't be able to use the SD-502. This is where the incompatibility is with certain devices.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
hacksawbob
PostPosted: Mon Jan 09, 2006 12:29 pm    Post subject: Reply with quote
storage card did not appear after driver install and reboot
xda
PostPosted: Mon Jan 09, 2006 2:27 pm    Post subject: Reply with quote
You won't see a directory called Storage Card, only if you have an SD card installed.
The SD-502 device driver will create a new one called GPSDisk Card.
If it doesn't do this then your device is incompatible.
I would suggest you return it and perhaps exchange it for a BT GPS unit.
Graham.
Nokia 925 Windows 8
Mehanik
PostPosted: Wed Jan 11, 2006 11:20 am    Post subject: New driver version. Reply with quote
There are new driver version on www.globalsat.com.tw - v1.33.
Please try it.
Mikhail E. Veselov
http://www.globalsat.su
GlobalSat Russia
teb
PostPosted: Thu Jan 12, 2006 10:43 pm    Post subject: Re: New driver version. Reply with quote
Please try it.
Mikhael hav you tried the new driver with a qtek s100/imate jam or mda compact to check for compatibility?
hacksaw have you returned your sd-502 unit yet? just wondering if you could try the new 1.33 driver before returning it. the 1.32 driver didnt work on my qtek s110. graham tried everything but it still wouldnt detect the card. Sad
PostPosted: Thu Jan 12, 2006 11:44 pm    Post subject: Reply with quote
The new driver doesnt work with either the Orange SPV M500 (TMobile MDA etc) or the O2 XDA Exec.
Globalsat R&D are currently working on the driver for these devices, but no release date is mentioned.
Mehanik
PostPosted: Fri Jan 13, 2006 9:52 am    Post subject: Reply with quote
Anybody knows difference between driver v1.33 and previous versions? Question
Mikhail E. Veselov
GlobalSat Russia
xda
PostPosted: Fri Jan 13, 2006 1:02 pm    Post subject: Reply with quote
The only file change in the Cab file is
GPSDis~2.004 size 155 dated 25-11-2005 for version 1.32
To
GPSDis~3.004 size 155 dated 11-12-2005 for version 1.33
The CAB file contains 5 files
OGPSDisc.001 size 24,576 dated 11-12-2005
OGPSUrart.002 size 18,432 dated 11-12-2005
GPSDis~1.00 size 1,814 dated 11-12-2005
GPSDisco.003 size 5,123 dated 11-12-2005
Graham.
Nokia 925 Windows 8
Philc1
PostPosted: Tue Jan 17, 2006 4:55 am    Post subject: Reply with quote
Can someone help?
I bought a SD-502 from PDAMODS before christmas for my girlfriend's rz1710 after first being assured it was compatible.
After installing the software that was on the CD, and then downloading and installing an updated driver (not sure whether this is 1.32 or 1.33 - need to check) when the card is inserted it keeps coming up with a "card not recognized" message! The GPS card does not show on the directory either. I have had next no help from PDAMODS their technical support function is absolutely useless.
Does anyone have any suggestions??? Sad
s_yeow
PostPosted: Mon Jan 30, 2006 5:22 am    Post subject: rz1710 works with new v1.33 driver Reply with quote
Philc1 wrote:
Can someone help?
I had the same problem with my rz1710. Download the latest driver v1.33 from http://www.globalsat.com.tw. Copy the zip file to your rz1710. Tap once and it will install. It works after that! Hooray!
Philc1
PostPosted: Wed Feb 01, 2006 3:05 am    Post subject: Reply with quote
Thanks - just checked into the forum to see whether I'd had a reply.
I downloaded 1.33 and clicked on the zip file within the PDA and it seemed to install ok but still no joy. I even tried soft resetted and it was still coming up with the same error message "card not recognised". I think I'm going mad - the only thing I think of is that something on the PDA is conflicting, but can't think what it is. There is only the bog basic PDA software and TomTom and that's it! Any ideas??? Question
s_yeow
PostPosted: Wed Feb 01, 2006 9:40 am    Post subject: Problem with writing to onboard memory Reply with quote
I got the GPS part working with my rz1710. However, when I try to upload maps to the onboard 512MB memory, I keep getting "error writing file". If I adjust the module slightly, some files will write to the memory. After some time, I will get "error writing file" again. It seems to me that the contact points between the SD module and my rz1710 is bad. I tried with another SD card, I have no problems! I will ask for a replacement. If the result is still the same, I will have to return the unit.
Moris
PostPosted: Thu Mar 02, 2006 10:40 am    Post subject: Reply with quote
Hello everybody (as it is the first time for me). I am also getting a bit frustrated about my SD 502. I am trying it with Xda II mini. I also try hundreds of times installing the drives and program. It does not recognize the COM port. I got even more confused when I received a message from the support from Taiwan saying that Xda II mini is not compatible with SD 502, while on the USA Globalsat web (http://www.usglobalsat.com/item.asp?itemid=17&catid=) the Xda II mini is listed as compatible Confused . Has anybody try to work with SD 502 and Xda II mini? :D
Page 2 of 4
