worthingsaxovtr Lifetime Member
![](modules/Forums/images/avatars/13404244754465a82fc6d33.gif)
Posted: Tue Jan 10, 2006 2:55 pm Post subject: number of questions |
hi there,
how do i remove scaredycatts appliactions ?
is it then worth upgrading to v5.420
and how do i sintall the adding spped camera software of here
cheers
nigel |
![](modules/Forums/images/avatars/32928398450ec149ec6abd.gif)
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Tue Jan 10, 2006 3:28 pm Post subject: |
Hi worthingsaxovtr,
If you wish to remove scaredycat's applications, then just reverse the process that you used to install them. I’m afraid that I’m not familiar with them, so I don’t know which folders or files you need to remove if you do it manually. Did you take a backup before? If you did why not restore from that backup?
If you wish to use any third-party application then don’t upgrade to 5.420. You won’t be able to use scaredycat’s applications, nor POI Capture.
If you go to this page, you’ll find the downloads and instructions for installing POI Capture.
Garmin Camper 770 LMT-D |
Andy_P Pocket GPS Moderator
Posted: Tue Jan 10, 2006 4:00 pm Post subject: |
I wrote this then went to lunch having only previewed it, so sorry if I'm repeating Privateer's
The speed camera application from here will only work with 5.202 as well.
Everyone is still waiting for a new version of the Developers' Kit from TomTom
To remove Scaredycat's stuff I think you just reverse the install instructions. So:
Remove the SdkRegistry, skin and catapps folders to your Go.
Remove "Mycams.ov2" and "Mycams.bmp" from your map directories.
If you used Autoswitcher and SatSync, remove the cleanup.txt file from the root directory. |
