Pocket GPS World :: View topic - Audible speed camera
grayus
PostPosted: Thu Jan 05, 2006 12:54 am    Post subject: Audible speed camera Reply with quote
I do not know if anyone has experienced this prob. I have just transferred my Tom Tom 5.1 GB plus maps onto a larger SD card then installed the speed camera's , they show on the screen but now I get no audible warning. every thing worked perfectly ok before I transferred the prog.I did exactly the same as I did on the old card , any advice appreciated.
thanks guys
tanda
PostPosted: Thu Jan 05, 2006 1:40 am    Post subject: Reply with quote
Hi Grayus, Have you checked to see if the "Alert of POI" is activated in your options, as you have just downloaded the speed camera database, this option will be off untill you activate it.
Audi A3 Sline sat nav
grayus
PostPosted: Thu Jan 05, 2006 1:48 am    Post subject: Reply with quote
Yep done that ,I did not download the speed camera's as I had the latest download already on my PC so i just installed them from my PC via my card reader.thanks for your interest.
tom tom 5.1 Ipaq 2210 rikiline 6010 reciever amplified mount
PostPosted: Thu Jan 05, 2006 8:49 am    Post subject: Reply with quote
Has the volume got turned down accidently? Do you get the Routing Directions OK?
grayus
PostPosted: Thu Jan 05, 2006 1:11 pm    Post subject: Reply with quote
Hi Rich .
Volume fine, same as I said every thing works AOK apart from no audible warning for speed camera's I replaced the original card last night and that worked fine , so it has to be something in the transferto the other card but I am blessed if I know what it is I did , If no one can help and I find out why I will post it up in case anyone else has the same prob.
many thanks
PostPosted: Thu Jan 05, 2006 2:32 pm    Post subject: Reply with quote
When, you did the install did you put the whole lot including the program onto the SD? The warnings are contained in a file called data.chk which normally resides in the programe files/ Navigator folder, make sure this file is in the correct place, also if you have modifed this file for real spoken alerts please make sure it is the correct file you have loaded in relation to the software version of TomTom you have loaded - Mike
grayus
PostPosted: Thu Jan 05, 2006 4:53 pm    Post subject: Reply with quote
Hi Mike
I think that I have sussed it out, I unticked every thing in the POi ,made sure the SD card was unlocked re ticked the POI and re set the required sounds and distance . and glory be it worked.these things are so frustrating at times.
many thanks all for your interest .
Kind regards
Graham
PS when one updates the speed camera's does it overwrite the existing ones or does it just add the updates ?thanks for your time ..
Pocketgps
PostPosted: Thu Jan 05, 2006 9:12 pm    Post subject: Reply with quote
It normally over writes the existing.
22.063 (19 Jun 24)
