Pocket GPS World :: View topic - Ipaq HX4700
Ipaq HX4700
Pat Boy Slim UK
PostPosted: Wed Jan 04, 2006 6:30 pm    Post subject: Ipaq HX4700 Reply with quote
Does anybody else's HX4700 lock up and totally reset itself back to factory settings ?
HP HX4700,2 GB Kingston SD,Fortuna Clip-on Bluetooth GPS, TomTom 5,Dell Axin X50,Destinator 6,Kingston 1GB SD Card,Nokia N80 smartphone,1GB Kingston ,TomTom mobile 5,Nokia N95 Smartphone,2GB Kingston MSD Card,TT One XL WE Traffic.
SimonCatlin
PostPosted: Wed Jan 04, 2006 6:46 pm    Post subject: Reply with quote
Is your battery fully charged?
iPhone5, TomTom, Google maps, Navfree, Viewranger and Apple Maps (ekk)
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
Pat Boy Slim UK
PostPosted: Wed Jan 04, 2006 6:53 pm    Post subject: Reply with quote
Yes battery is full,it just locks up and wont quick reset.
Pat Boy Slim UK
PostPosted: Wed Jan 04, 2006 6:54 pm    Post subject: Reply with quote
I wish i kept my 3970 now ! never had any trouble with that !
SimonCatlin
PostPosted: Wed Jan 04, 2006 8:01 pm    Post subject: Reply with quote
I think the battery is knackered to be honest. Is this a soft reset or a full system reset you get everytime (thus you are having to restore)?
The only time I have to do a full restore (and reset factory setting) is when the battery runs out.
daveLDC
PostPosted: Wed Jan 04, 2006 8:01 pm    Post subject: HX4700 Reply with quote
I had a slight problem when I first got mine, the battery "slide lock" on the base would not lock properly and seemed to re-set the unit. I had to remove the battery, re-insert, and then the locking mechanism seemed to be ok.
The only other time was when I was using the original Tom Tom Navigator 5 software when the HX4700 would return to the "today page" and soft reset. This was not a hard re-set though. To cure this I upgraded to Tom Tom Navigator 5.100 (5160). I have not downloaded version 5.2 yet as it seems OK as it is.
Rgds,
Dave.
Dave LDC
HP HX4700
Navigator 5 Bluetooth (Hole in the middle).
SEIDIO 2500 Amplified mount.
Pat Boy Slim UK
PostPosted: Wed Jan 04, 2006 8:24 pm    Post subject: Reply with quote
the battery is ok,its only 2 weeks old .my other hx4700 went faulty and HP replaced it,so i have 2 batteries and have tried them both !
lupos0_1
PostPosted: Wed Jan 04, 2006 8:54 pm    Post subject: Reply with quote
Sounds like this one is faulty 2!!
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
PostPosted: Wed Jan 04, 2006 10:28 pm    Post subject: Reply with quote
What software are you running when this occurs?, also what is the battery status indicator showing for both the Main Battery and Backup Battery - it could be a bad connection between the IPAQ and battery, make sure non of the contacts between the two are damaged or bent in any way - Mike
Pat Boy Slim UK
PostPosted: Thu Jan 05, 2006 1:41 am    Post subject: Reply with quote
batteries are above 90% and the ipaq does'nt need to be running anything for this to happen.all connections are ok.
Pat Boy Slim UK
PostPosted: Thu Jan 05, 2006 1:55 am    Post subject: Reply with quote
Pat Boy Slim UK
PostPosted: Thu Jan 05, 2006 2:45 am    Post subject: Reply with quote
SimonCatlin
PostPosted: Thu Jan 05, 2006 10:33 am    Post subject: Reply with quote
Ok - we heard you the first time :D
I think you need to reject the 4700 as defective on arrival. All maufacturers will ship you a replacement unit that may have been another customers' reject in a previous life.
I had my motherboard swapped on my hx4700 after doing a ROM update and now (six months later) I can see they damaged a part of the screen!
Nothing I can do.
robbie
PostPosted: Tue Jan 10, 2006 10:08 am    Post subject: Reply with quote
Had exactly the same problem as you described. Courier was sent to pick up old 4700 and new one returned within in 3 days.
Rob
gbh
PostPosted: Tue Jan 10, 2006 1:43 pm    Post subject: Reply with quote
Seems to be a common fault with 4700 - Rom upgrade screws up (I had same problem & had to send it away to have motherboard replaced as well).
Not suffered from many hard resets though, only had two - 1 accidentally loosened the battery lock clip, 2 software install clashed with other programs.
Other than that no problems since bought 6 months ago
22.062 (12 Jun 24)
