marksfish Pocket GPS Verifier
Joined: Jun 25, 2005 Posts: 802 Location: Sandy, Bedfordshire
Posted: Tue Jan 03, 2006 7:58 pm Post subject: POI Graphics |
I have created a new POI folder using the TT Wizard type thing!! I initially allocated a default graphic for ease in finding when approcahing the areas. I have since tried to change this graphic to something more personal. I have replaced the TT default graphic with a GIF image and a JPEG image, both times I only get the default red square when aproaching.
Is there an easy way to make POI graphics please?
Mark _________________ Garmin Drivesmart 51 LMT-D Europe |
Joined: 30/12/2002 17:36:20 Posts: 4912 Location: Oxfordshire, England, UK
Posted: Tue Jan 03, 2006 10:45 pm Post subject: Re: POI Graphics |
Hi marksfish,
If you want to make icons for TomTom POIs then I recommend MS Paint, as I have found it to be the best (easiest) package to create icons. You can use MS Paint to resize a graphic and edit it.
The key requirements for an icon are:
Must be .BMP format.
Must be no larger than 22 x 22 pixels.
Must use no more than 256 colours.
Garmin Camper 770 LMT-D |
Posted: Tue Jan 03, 2006 10:56 pm Post subject: |
Ah, that will be where I am going wrong Robert. I had also tried bitmap (forgot to mention in last post, but the size was 29x22 (I figured that as it was 22 high that would be okay). I have now resized to 22x17 (a bit small, but functional) and it appears as it should.
Thanks for your help.
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Wed Jan 04, 2006 1:38 am Post subject: |
marksfish wrote: | Ah, that will be where I am going wrong Robert. I had also tried bitmap (forgot to mention in last post, but the size was 29x22 (I figured that as it was 22 high that would be okay). I have now resized to 22x17 (a bit small, but functional) and it appears as it should.
Mark |
The size can be 23 x 23 if that makes it easier to make the icon you want.
That size works fine with TomTom 3 & 5 & also Navigon 4 & 5 on a PDA so it should work on a GO or ONE etc. |
clem556 Occasional Visitor
Joined: Sep 12, 2005 Posts: 23 Location: South Oxfordshire
Posted: Tue Jan 10, 2006 1:25 pm Post subject: navman pin570 |
I am also struggling to get "custom" icons to show. I loaded some POI's fro the navman POI's listed on your forum, they import fine exept for the icon. I have followed the instructions (limited as they are) found in the habd book but to no avail. |
