fcombar Occasional Visitor
Posted: Fri Dec 30, 2005 6:14 am Post subject: Palm T3, TT N5 Travel Via Planning |
How do you use more than one "Travel Via's" in a route plan? |
peterc10 Frequent Visitor
Joined: Aug 21, 2005 Posts: 1761 Location: Kent, England
Posted: Fri Dec 30, 2005 1:59 pm Post subject: |
Use itenaries to set as many waypoints as you want. You will then be routed to them in the order you put them in (TT won't work out the best order for you) |
Posted: Fri Dec 30, 2005 3:32 pm Post subject: |
I was trying to use the "Cursor Function" to select two different roads on a route using "Travel Via". The first point chosen is labled with a "1". When I select a second point the first point selected is removed and the second point selected. I want to have both roads selected on the route. How do I do that. |
Posted: Fri Dec 30, 2005 8:36 pm Post subject: |
You can't do it using "Travel via".
Instead go into "Itineray planning" and "add" waypoints - can be done by address, map, postcode etc. Once you have added all you want to hit the Options tab (bottom right). From there you can save them for later use or if you want hit "start navigation" and you will be guided to the first. |
Posted: Sat Dec 31, 2005 5:59 am Post subject: |
Thanks peterc10, I'll try it. Appreciate your input. Happy New Year |
Robin2 Lifetime Member
Posted: Sat Dec 31, 2005 2:16 pm Post subject: |
It's worth mentioning that you can't plan an itinerary with TT5 unless you are connected to a GPS receiver and the itinerary starts from the GPS position (You could do this in TT3)
BUT, from version 5.1 onwards there is a workaround which enables you to fool TT5 into believing that it has a GPS fix. It is described in Lutz Bendlin's bug list in the stickies at the beginning of this forum. It works well, and when you are used to it you can plan an itinerary offline almost as quickly as with TT3
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
