Pocket GPS World :: View topic - Making a copy of SD card - problem?
Towunda
PostPosted: Fri Dec 30, 2005 2:52 pm    Post subject: Making a copy of SD card - problem? Reply with quote
Hi everyone! I've copied all the stuff on my TT sd card to my pc, I have now copied that info onto a spare SD card. For some reason my TT300 doesnt like the copied card??? I'm using a 512mb - maybe its to big??? or am I doing something wrong??? Cheers everyone. Confused
berkeley384
PostPosted: Fri Dec 30, 2005 2:56 pm    Post subject: Reply with quote
Is your computer set up to show hidden files
If not you may not have copied it all across
Towunda
PostPosted: Fri Dec 30, 2005 3:19 pm    Post subject: Reply with quote
Hi, I've checked both cards, I have the same files on both but TT still doesnt like the copied card??? I don't know if my PC is set to show hidden files??? Cheers
TT300_Owner
PostPosted: Fri Dec 30, 2005 3:22 pm    Post subject: Reply with quote
To see hidden files on your system :
1) Open Windows Exlorer
2) From the Tools menu, select "Folder Options"
3) Click the "View" tab
4) About the 9th item down, select "Show hidden files and folders"
However, you shouldn't really keep this set if you don't know all about the system files on your computer - you could delete one sometime and stop your system working....
It's best to do the backup and restore via your TomTom using the TomTom software that came on your CD.
JLee
PostPosted: Fri Dec 30, 2005 3:35 pm    Post subject: Reply with quote
TT300_Owner wrote:
...However, you shouldn't really keep this set if you don't know all about the system files on your computer - you could delete one sometime and stop your system working....
That's true but you've not advised Towunda to show 'protected operating system files', which is much more likely to cause major problems if deleted. So the really important files will remain hidden as they should be.
Towunda
PostPosted: Fri Dec 30, 2005 3:49 pm    Post subject: Reply with quote
Thanks guys, Ive tried the above, still no go.Think I must be doing something wrong somewhere!!! cheers anyway.
TT300_Owner
PostPosted: Fri Dec 30, 2005 4:08 pm    Post subject: Reply with quote
JLee wrote:
[That's true but you've not advised Towunda to show 'protected operating system files', which is much more likely to cause major problems if deleted. So the really important files will remain hidden as they should be.
Yep - true :D I forgot there was an extra option there about the system files...
Towunda are you doing this backup through your TomTom, or through a separate card reader?
Towunda
PostPosted: Fri Dec 30, 2005 4:11 pm    Post subject: Reply with quote
...i did it through the card reader on my PC.
TT300_Owner
PostPosted: Fri Dec 30, 2005 4:14 pm    Post subject: Reply with quote
You should try connecting the TomTom to your computer through the USB lead and then use the Backup/Restore software that came with the TT. When you put the CD in the drive, the first option (I think) is to back/restore.
Towunda
PostPosted: Fri Dec 30, 2005 4:19 pm    Post subject: Reply with quote
yeah, I did that as well, and then copied that onto the spare card, but TT doesnt like that either!!!
TT300_Owner
PostPosted: Fri Dec 30, 2005 4:21 pm    Post subject: Reply with quote
When you say the TT doesn't like it, what's happening on the TT after you've completed the restore?
TT300_Owner
PostPosted: Fri Dec 30, 2005 4:23 pm    Post subject: Reply with quote
Maybe your TT doesn't like the card you have. You should check the first thread at http://www.mytomtomgo.com/forum/viewforum.php?f=18&sid=505a1ed5cdc3db6e36fb1b1b1c334efd to see if it's been a problem with other users.
512MB is certainly not too large for your TT.
Towunda
PostPosted: Fri Dec 30, 2005 4:24 pm    Post subject: Reply with quote
when I put the copied card in I get an illistration of the TT and an animated picture of the card coming out and then a red cross on the card.
TT300_Owner
PostPosted: Fri Dec 30, 2005 4:28 pm    Post subject: Reply with quote
Don't know if you saw my post about checking your card at http://www.mytomtomgo.com/forum/viewforum.php?f=18&sid=505a1ed5cdc3db6e36fb1b1b1c334efd because I posted it soon after my last post!
Try formatting the new card again and trying the restore again through your TT.
Towunda
PostPosted: Fri Dec 30, 2005 4:30 pm    Post subject: Reply with quote
yeah, I just been looking at that site, looks like a few others have had the same problem. I'll give the formatting a go but it might be that I need to change the brand of card. Thanks everyone - you been great! :D
22.064 (26 Jun 24)
