Darren Frequent Visitor
Posted: Fri Dec 30, 2005 2:19 pm Post subject: |
I always suggest buying an adapter that plugs into a mains socket and allows you to connect devices that have a cigarette lighter charger lead.
They come in incredibly useful for all manner of stuff and are very cheap.
See here. _________________ Darren Griffin |
TT300_Owner Regular Visitor
Posted: Fri Dec 30, 2005 3:17 pm Post subject: |
This adapter is fine - your TomTom lead will supply the correct voltage to your TT.
You need a normal SD card - this one is on the same site : http://www.mobilefun.co.uk/product/8622.htm |
The Mains-12v cigarette lighter adapter outputs 12v so will power any device that has a cigarette lighter lead.
The ONE takes about 2hrs to fully charge.
The SD card is the full size one and not the mini-SD. _________________ Darren Griffin |
Oldboy Pocket GPS Moderator
Posted: Fri Dec 30, 2005 4:09 pm Post subject: |
onesexylady wrote: | How long does it take to charge and I guess you have to keep an eye on it as it doesnt turn off when fully charged like some? |
It won't overcharge. The Lithium-Ion battery can be left on charge for over 24 hr. _________________ Richard
Klanden Occasional Visitor
Posted: Sat Dec 31, 2005 12:46 am Post subject: |
I purchased a 256mb Integral HIGH SPEED SD Card from Maplin Online for £19.99 and this works fine with my TomTom One and it's loaded with voices, POI's, etc.
I tried the standard (not High Speed) Intergal Card from Maplin 1st, but truncated the end of the voices instructions, so if you go for an Intergal SD Card make sure it's marked "HIGH SPEED" and it should work OK. |
nightriders Occasional Visitor
Posted: Tue Jan 03, 2006 6:18 pm Post subject: Chargers |
For what it's worth I have purchased a world travel charger for my ttg 300 on ebay for £11.50 with adaptors for foreign travel.
It works very well |
soggs_k9 Occasional Visitor
Posted: Mon Jan 29, 2007 11:51 pm Post subject: |
Regarding the voltage etc. Anyone know what the Volts/amps is for the TT1 Regional? I wonder if I can use my Motorola phone charger on the TT1, both charge from the computer via USB. Might be handy to use the same car lead for both.
Stu |
Andy_P Pocket GPS Moderator
Posted: Tue Jan 30, 2007 1:05 am Post subject: |
The maximum power available from a single USB socket is 2.5 watts (500 mA @ 5 v).
Anything that is designed to charge from the USB bus should conform to the USB standards, so they should be interchangeable. |
Posted: Tue Jan 30, 2007 6:34 pm Post subject: |
Thanks for that, I have a curly cord car charger for my motorola which has a mini usb connector. It's a bit tidier in the car than the supplied cable and doesn't get in the way of other stuff.
Cheers, Stu. |
tonygold Frequent Visitor
Posted: Tue Jan 30, 2007 7:08 pm Post subject: |
onesexylady wrote: | Great that sounds easy enough!
Does anyone know the best place to get a charger for the one aswell, either the real one or alternative?
Don't have a psp so cant use that |
remember that once you plug your ONE into the usb port of your computer that will charge your device. |
trevor.dowle Lifetime Member
Posted: Tue Jan 30, 2007 7:27 pm Post subject: |
TomTom version 2 might, but TomTom version 1 definately doesn't charge from USB connections.............. _________________ Regards
Trev Dowle
TomTom 730 T |
Posted: Tue Jan 30, 2007 7:34 pm Post subject: |
correct. but as her tomtom was bought this xmas, i assumed it must be a v2????? |
