Pocket GPS World :: View topic - Editing POI file ??
Editing POI file ??
paulthetool
PostPosted: Sat Nov 26, 2005 3:44 pm    Post subject: Editing POI file ?? Reply with quote
Hi all,
is it posible to edit EVERY line in a POI file in one go without doing it line by line?
I would like to edit the description of every line in the gatso file
just to leave the speed. IE from GATSO:1518@60 to just 60 ?
this will allow me to show the speed next to the cam icon on the map
without the GATSO:1518@ bit cluttering up the map
Paul
paulyoung04@aol.com
Pocketgps
PostPosted: Sat Nov 26, 2005 8:08 pm    Post subject: Reply with quote
If you load it into Excel then you could remove that column and replace it with whatever you require.
paulthetool
PostPosted: Sat Nov 26, 2005 8:23 pm    Post subject: Excel Reply with quote
I know I will be able to remove the whole colum with excel but it will also remove the speed part at the end !
Paul
Oldboy
PostPosted: Sat Nov 26, 2005 8:29 pm    Post subject: Reply with quote
You could use something like Word to Find & Replace. Don't save it as a .doc file though.
Tim Buxton
PostPosted: Sat Nov 26, 2005 8:30 pm    Post subject: Reply with quote
But then you'd have so many hundred(?) POIs called 30, which might confuse the software somewhat.
Tim
Oldboy
PostPosted: Sat Nov 26, 2005 9:26 pm    Post subject: Reply with quote
... and also which one had been removed/changed etc.
Pocketgps
PostPosted: Sun Nov 27, 2005 4:12 pm    Post subject: Re: Excel Reply with quote
Paul
You can select via the different menus within Excel what to remove in each column, you can break down each column and split it how you require, so no it does not remove all of the data.
You can put column breaks where ever you require, that's the whole point of Excel.
paulthetool
PostPosted: Sun Nov 27, 2005 4:54 pm    Post subject: Excel Reply with quote
I am trying to do this in Excel, but not sure what function to use ? Confused
JLee
PostPosted: Thu Dec 29, 2005 11:02 am    Post subject: Re: Excel Reply with quote
Paul
Just create a new column next to it and use a formula to leave the speed at the end. This assumes that the original column is A, the new column is B and the speed at the end is 2 characters:
1. Click in cell B1 and type the formula =Right(A1,2) and press enter.
2. Highlight all cells in column B down to row n where n is the last row that is filled in in column A (so if data in column A goes down to A350 highlight cells B1 to B350).
3. From the menu select Edit>Fill>Down.
4. Highlight the whole of column B and Edit>Copy, followed by Edit>Paste Special>Values.
5. That should give you what you want so just delete column A
22.064 (26 Jun 24)
