Pocket GPS World :: View topic - Spoken POI alerts for TomTom GO, Mobile, PocketPC and Palm
Goto page Previous  1, 2, 3 ... 42, 43, 44 ... 71, 72, 73  Next
don_kedik
PostPosted: Wed Dec 28, 2005 1:05 am    Post subject: Reply with quote
it showed the pocket gps gatso sybol i didnt asign a tone, i have looked into assigning tones for that symbol but then wouldnt it just then say gatso 50 for all the gatso cameras
i have on my tt1 these camera types
gatso
mobile
redlight
uk specs
uk temp
i have just reinstalled the data.chk file could u please guide me through what needs to be done
rayflan
PostPosted: Wed Dec 28, 2005 1:26 am    Post subject: Reply with quote
As you're not using the speed zoned camera pois just assign the single camera warning for each type.
For the gatso poi assign the gatso sound for the mobile assign the mobile sound and so on.....
As Oldboy says..........
There can be 3 setups for speed cameras.
The first is a single file that contains all the cameras together, without any reference to what type. This is named pocketgps_uk_sc.ov2 and found in the 'single file version' folder.
Second is the 5 file version that divides the cameras into types. Gatso, Mobile, Specs, Redlight and Temporary. These you will find in the 'ov2 bmp' folder.
Third is the full version that divides the Gatso Mobile and Specs files into speed zones. These are found in the 'speed zoned folder’. Add to these the Redlight and Temporary files as above.
I have not included the Continental file because you will only need this if going to the continent.. But should you want it , it's in the 'ov2 bmp' folder.
When you've decided which set you want copy each .ov2 file, and it's matching .bmp file to your map folder. Then setup the POI's in Manage POI.
Ray
New Url www.tomtomsatnav.info
Visit my site
don_kedik
PostPosted: Wed Dec 28, 2005 1:41 am    Post subject: Reply with quote
ok cheers done that mostly but what do the symbols
red circle ?
red circle *
yellow background gatso specs which cameras r these and what sound do i put to these sybols
many thanks nearly there
rayflan
PostPosted: Wed Dec 28, 2005 1:53 am    Post subject: Reply with quote
Red circle ? - unknown speed gatso.
Red circle * - variable speed gatso.
Yellow background gatso specs - these ae average speed cameras.
Ray
Visit my site
KnightOwl
PostPosted: Wed Dec 28, 2005 6:48 pm    Post subject: Re: Spoken POI alerts for TomTom GO, Mobile, PocketPC and Pa Reply with quote
MikeB wrote:
A PocketGPSWorld.com TomTom World Exclusive: Spoken warnings for POI alerts!
I have v5.42 of the Tomtom RIDER and the version online does not work correct with the RIDER but does work with the GO 700 using the same version of the software.
Paul
ICQ Number
ColinUk
PostPosted: Wed Dec 28, 2005 8:39 pm    Post subject: Reply with quote
Trying to load extended warning into my TT GO.
Would appreciate help please.
It says to copy modified TTN file and data.chk from modified folder to the root/main folder on TTGO.
Do I replace the ttsystem file with TTN file or add TTN file?
Colin
KnightOwl
PostPosted: Wed Dec 28, 2005 9:06 pm    Post subject: Reply with quote
Hi Colin,
It says: "Copy the modified TTN file and data.chk file from the modified folder to the root / main folder of your TTGO and reboot"
Further on the same page it says: "Restore to Original State.
Delete the ttn file and replace the original data.chk
So by conclusion I would suggest you do not copy over the ttsystem file!
Paul
ICQ Number
PostPosted: Wed Dec 28, 2005 9:15 pm    Post subject: Re: Spoken POI alerts for TomTom GO, Mobile, PocketPC and Pa Reply with quote
When you say "does not work correct" how does this manifest itself?
rayflan
PostPosted: Wed Dec 28, 2005 9:18 pm    Post subject: Reply with quote
Hi Guys,
Leave the ttsystem in place and add the ttn file.
Replace the original data.chk file with your modified one.
As always make sure you have a working backup first.
Ray
Visit my site
berkeley384
PostPosted: Wed Dec 28, 2005 11:11 pm    Post subject: Reply with quote
Hello Rayflan
Im using a new Tom Tom One - software versian is 5.410 -Can I use your tool, If so which voices do I use 22050 or 16000
Many Thanks
Stephen
berkeley384
PostPosted: Wed Dec 28, 2005 11:59 pm    Post subject: Reply with quote
Apologies for the double post, but if it does work, it doesnt work for me,
I copied the TTSystem file from the TT One, I pasted it into the extractttn folder, I clicked on the extract_ttn.exe file and it said it had been able to create the ttn file in the Bin folder
I opened the bin folder right clicked the ttn file and copied it , pasted it in to the "Originals" folder within the Poiextend folder
When I opened the ttn_poiew.exe program and loaded the ttn file from the "originals folder it says .....
TTN file C:\Documents and Settings\Stephen\My Documents\Test\poiextend\originals\ttn
....does not appear to be a TomTom file.
Im wondering where Ive gone wrong ?
Stephen
rayflan
PostPosted: Thu Dec 29, 2005 12:01 am    Post subject: Reply with quote
berkeley384 wrote:
Hello Rayflan
Many Thanks
Stephen
To extend the warnings I'd say no but give it a go. You should be able to modify the data.chk with 15 sounds. It's 22050 you need.
You should also be able to upgrade to 5.42
Ray
Visit my site
berkeley384
PostPosted: Thu Dec 29, 2005 12:41 am    Post subject: Reply with quote
Thanks - software upgraded and indeed it now lets me modify
However, the.exe shows Ive clearly got the right wording with the right sound file but when this is uploaed to the Tom tom there all wrong
Its as if there all 3 behind if that makes sence Gatso 60 says 30 - Gatso 70 says 40 etc
Any ideas ?
Many Thanks
rayflan
PostPosted: Thu Dec 29, 2005 12:49 am    Post subject: Reply with quote
Are you modifying the ttn and the data.chk or just the ttn and using a downloaded data.chk?
Ray
Visit my site
berkeley384
PostPosted: Thu Dec 29, 2005 1:14 am    Post subject: Reply with quote
I was doing both
Page 43 of 73
23.052 (14 May 25)
