Pocket GPS World :: View topic - TT One activation after copying files to backup SD card
JimC
PostPosted: Wed Dec 28, 2005 6:33 pm    Post subject: TT One activation after copying files to backup SD card Reply with quote
Using a card reader I copied the TT One SD card contents to a folder on my computer then copied the files back to a blank SD card so I could keep the original safe.
When I put in this copied SD card the One asks to be activated, I enter the code supplied with the unit but it come up saying it is not a valid activation code for the UK map.
Any suggestions about what I might have done wrong and what I should try next?
Jim C
PostPosted: Wed Dec 28, 2005 6:48 pm    Post subject: Reply with quote
When you copied the original card did you select show hidden files in windows explorer on the PC? this usually works for TTN but not 100% sure as to the unit you have, it might be worth a try though - Mike
Frazz
PostPosted: Wed Dec 28, 2005 6:49 pm    Post subject: Reply with quote
I think you may need to use the CD to create a back up rather than just copying the card. You then create the backup with you TomTom plugged into a USB port rather than taking the card out and using a reader. I first created a back-up and then copied the backup onto a new SD card and this worked OK for me.
Frazz
mossman
PostPosted: Wed Dec 28, 2005 7:27 pm    Post subject: Reply with quote
I have a TTOne, and did exactly the same thing as JimC - copied original card via a card reader, but ensured that I had the Explorer option checked to show hidden files. Copied back to larger card (again via card reader), and it worked in the TTOne, no problems.
The cd backup option will undoubtedly work, but it will be alot slower than a usb2 cardreader Sad
sgould
PostPosted: Wed Dec 28, 2005 7:58 pm    Post subject: Reply with quote
The code on the card is NOT the activation code. The code on the card is the "Product Code". Go to www.ttcode.com and enter the Product Code and the Device Code from the ONE (Change Prefs/Show Version). This will get you an activation code to enter.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
mossman
PostPosted: Wed Dec 28, 2005 11:12 pm    Post subject: Reply with quote
I've got to add that, when I performed by copy/restore to a new card, I was not asked for an activation code - this makes me think that there may be a file or two missing from that original copy.
sgould
PostPosted: Thu Dec 29, 2005 1:46 am    Post subject: Reply with quote
If you do a complete copy and restore you won't get asked for the activation code, but if you then update the system, especially a major upgrade upgrade say from 4.42 to 5.2 you probably will be.
TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
