Pocket GPS World :: View topic - Help with spalashcreen
furryfred
PostPosted: Tue Dec 27, 2005 1:41 pm    Post subject: Help with spalashcreen Reply with quote
Can anyone point me towards a place where I can download a Landrover / Freelander splash screen for my TomTom Go 700 and how to install it?
Thanks in anticipation.
Furry Fred
(a very very nice, handsome and generous gentleman who is really rather modest, shy and retiring!)
They didn't make many like him - and now they've lost the mould!
Bigstoo
PostPosted: Tue Dec 27, 2005 2:10 pm    Post subject: Reply with quote
you just need to get hold of a landrover graphic in bmp format, upload it as splash.bmp to your go after renaming the original splash.bmp to oldsplash.bmp in the root folder.
its under discussion here: http://www.expansys.com/forumthread.asp?code=TOMTOMGO&thread=1430
hope this helps ;)
furryfred
PostPosted: Tue Dec 27, 2005 3:19 pm    Post subject: Reply with quote
Thanks,
The first thing I noticed on the discussion flagged was a warning as to the versions supported.
I am using the latest update (5.420) and understand that this will not work with certain software (such as the POI Cature software)
Will the copying of sucha .BMP work with this version?
If not can someone advise me on the method in this case?
Furry Fred
PostPosted: Tue Dec 27, 2005 3:50 pm    Post subject: Reply with quote
All TTG's using V5.xxx have the same Splash.bmp specification.
PostPosted: Tue Dec 27, 2005 5:23 pm    Post subject: Reply with quote
There are loads of splashscreens HERE
Not sure if there is a LandRover one there yet but if you ask someone will probably make one for you.
meclive
PostPosted: Tue Dec 27, 2005 6:24 pm    Post subject: Reply with quote
Can you change the splash screen on the tomtom one? i have followed the directions, e.g. make a .bmp of 320x240 and rotate 90* but i just get a black splashscreen.
Also is there anyway i can display my current speed on the tt one? like when im following a route can it display my current speed?
meclive
PostPosted: Tue Dec 27, 2005 6:40 pm    Post subject: Reply with quote
Thanks a lot dan :D
Im still having trouble with the splashscreen though Confused Im folliwing the instructions but all im getting is a black splashscreen like it cant load it. Im using this file can anyone check to see if its ok. thanks.
[img]http://image.cfsmedia.co.uk/images/59537134.bmp[/img]
sgould
PostPosted: Tue Dec 27, 2005 7:13 pm    Post subject: Reply with quote
Common problem is that you have extensions hidden and that the splash screen is arriving on the GO with the name of "splash.bmp.bmp"
It will only work if it's called "splash.bmp" on the GO.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
meclive
PostPosted: Tue Dec 27, 2005 7:17 pm    Post subject: Reply with quote
Thanks but ive checked and that isnt the problem. Im pulling my hair out now Laughing Out Loud! Its the right size, a .bmp file, and its been rotated 90* clockwise in photoshop. I removed the original splash.bmp and then put this one on. Anyone got anymore ideas?
sgould
PostPosted: Tue Dec 27, 2005 7:23 pm    Post subject: Reply with quote
Saved as 24 bit bmp?
TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
meclive
PostPosted: Tue Dec 27, 2005 7:28 pm    Post subject: Reply with quote
No i saved it as a 8bit .bmp il try a 24bit one now.
meclive
PostPosted: Tue Dec 27, 2005 7:30 pm    Post subject: Reply with quote
Yay it worked! thanks a bunch sgould!!
sgould
PostPosted: Tue Dec 27, 2005 8:31 pm    Post subject: Reply with quote
:D :D :D :D
TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
furryfred
PostPosted: Tue Dec 27, 2005 9:43 pm    Post subject: Reply with quote
Managed to set up a 24 bit .bmp which was renamed to splash.bmp (old one renamed) size 2488 x 762 (3.7 Mb).
No problem doing that, but it doesn't work - I get a blank splash screen!
What am I doing wrong?
Furry Fred
PostPosted: Tue Dec 27, 2005 10:07 pm    Post subject: Reply with quote
It has to be reduced to 240 x 320 to work.
