Pocket GPS World :: View topic - icons instead of words??
daps
PostPosted: Tue Dec 27, 2005 2:32 pm    Post subject: icons instead of words?? Reply with quote
Help please.. I've upgraded to V6.. When I go into Routing for the routing type and Toll Roads all I get is a load of little icons, its the same in the Guidance with the drop down menus.
Is this normal. ? The instructions in the help files do not look like this.
Alan
Garmin 2569
Viper
PostPosted: Tue Dec 27, 2005 6:34 pm    Post subject: Reply with quote
Hi Daps,
Have you got Geopostcode installed on your PDA as well as Copilot 6?
The same thing happened to me, try a hard reset to get rid of Geopostcode and then just try installing copilot 6, you should then find the shapes and icons have disappeared.
Regards
Steve
daps
PostPosted: Tue Dec 27, 2005 9:30 pm    Post subject: Reply with quote
Steve..
Thanks for suggestion.
I've never heard of Geopostcode so I dont know if its on there or not.
I've got to transfer everything off the Mio in order to give it hard re-set.
Worth a try though. Icons are annoying.
Regards
Alan
Garmin 2569
Viper
PostPosted: Wed Dec 28, 2005 1:21 am    Post subject: Reply with quote
Hi Alan,
Has your hard reset cured the problem?
It is a stand alone program with a postcode database, and converts any postcode into a longitude and latitude reference which it then puts into a copilot trip file as a waypoint.
I used the program with copilot 5, but when I installed CP 6 I had to uninstall it, no worse do a hard reset to get the menus in CP6 working properly. When installing Geopostcode the installation installs a NS Basic/CE 5 Runtime language on your PDA, which I suspected could of been causing the problem, especially if it clashes with a similar language CP6 might utilise.
I wonder if you have any runtime files on your PDA, or programs which use them?
Regards
Steve
daps
PostPosted: Wed Dec 28, 2005 11:49 am    Post subject: Reply with quote
Hello Steve.
Whatever it was, re-set done the trick. I had visions of sending it back to ALK. The hard re-set cured it all. From what I remember I once D/L something called Runtime for VB??? so no doubt you hit the nail on the head.
Many Thanks for your help.
Regards
Alan
Garmin 2569
