Nick101 Occasional Visitor
Posted: Mon Dec 26, 2005 5:57 pm Post subject: Tom Tom One - blank screen stopped working |
Just got my Tom Tom One from Santa. Was working great yesterday, then today did the software upgrade to 5.420, all seemed fine. Tom Tom was showing my home address, I was reading the instructions to down load the camera POI, looked back at my Tom Tom to find it was powered off and blank. Tried to charge via the car charger, it shows charging but still won't turn on, any one ese had this problem? |
notorious19 Occasional Visitor
Posted: Mon Dec 26, 2005 6:23 pm Post subject: |
same kinda thing happened to me after i did the camera poi ,i had to do reset and it was fine but took the cameras off again after |
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Mon Dec 26, 2005 6:34 pm Post subject: |
You may need to make a bit of room on the card. Try removing any foreign voices you don't need.
Make a full back up to your PC before doing any changes.
Better still, copy your backup to a bigger blank SD card and use that as you day to day card. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Mon Dec 26, 2005 6:41 pm Post subject: |
thanks, I reset it and it seems fine now. Now all I have to do is down load the camera POI from this site...will try later, thanks again |
mossman Regular Visitor
Posted: Mon Dec 26, 2005 7:14 pm Post subject: |
I would certainly recommend buying an additional, larger (256meg) card for the UK maps, copy the supplied card over and use the larger one as your day to day card. Plenty of free space then for all the additional bits that I'm sure you'll want to put on. |
Andy_P Pocket GPS Moderator
Posted: Tue Dec 27, 2005 4:51 pm Post subject: |
Nick101: Even if it's working OK now, you might find it crashing when it's calculating routes unless you do whet sgould suggested:
sgould wrote: | You may need to make a bit of room on the card. Try removing any foreign voices you don't need. |
That's an easy first fix, if you don't want to get a bigger card yet. |
Posted: Tue Dec 27, 2005 7:18 pm Post subject: Andy: |
Thanks for the tip, I removed one voice, I only had two on it. Any way pleased to confirm the camera poi from this site are working ace and it seems fine.
cheers |
woodlands40 Occasional Visitor
Joined: Dec 28, 2005 Posts: 11 Location: West Midlands
Posted: Wed Dec 28, 2005 4:43 pm Post subject: |
I had the same problem. Charged my One overnight, used it the next day after adding the cam poi and a new voice. I used it untill the battery was flat then recharged it. It would not switch on untill i reset it with the trusty pin kept for the washer jets. No problems since then. |
