Bity Occasional Visitor
Posted: Fri Dec 23, 2005 6:17 pm Post subject: Slow signal pick up TT5 |
How long should it take to start receiving a signal with my TTN5 linked to my Acer X50. It can take anything from 5 minutes (rarely) to over 50 minutes. Once it has picked up a signal it works like a dream. I presently use a mobile receiver linked by bluetooth, but I also have a hard wire arial but gave up on that because that also took forever to get a signal. Any ideas anyone? |
lbendlin Pocket GPS Staff
Posted: Fri Dec 23, 2005 7:00 pm Post subject: |
Allow your receiver to get a fix BEFORE you start TTN. What you experience is very common with (unsupported) built in receivers, but can also happen with BT. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
mikewhite75 Occasional Visitor
![](modules/Forums/images/avatars/gallery/pirates6.jpg)
Posted: Sun Dec 25, 2005 1:41 am Post subject: |
Hi There,
I've also same problem, just to be more clear, what do you mean
do i need to turn the antenna first before start or something else
thanks |
Posted: Sun Dec 25, 2005 1:50 am Post subject: |
You need to wait until the GPS unit is seeing a signal, this is usually displayed on the LED segments fitted into the GPS unit itself, once this is signaling it has a signal then fire up the TomTom application - Happy Christmas Mike |
Posted: Sun Dec 25, 2005 2:45 am Post subject: |
thanks for your reply,
I never seen a green indicator on my mio 168, i bought it from http://www.globalpositioningsystems.co.uk/
they said it was a returned one but we checked all, it looks they didn;t check anything at all, i've a problem with my charger too i can not insert into pda
now just you light me up the gps indicator, really i'm fed up by them they told all lies
Thanks |
Posted: Sun Dec 25, 2005 5:39 pm Post subject: |
The Mio doesn't have an indicator. Just flip the antenna out and wait two to five minutes. You can use WinFast or another monitoring tool to understand if it has a fix yet. _________________ Lutz
Posted: Sun Dec 25, 2005 6:16 pm Post subject: |
Aftere power indicator, i've another indicatoru near to that what is that
then i'm new to pda can you tell where can i download winfast _________________ Thanks
Mike
Windows Mobile 2003 + Mio 168 + Tom Tom 5.21 + POI Capture + POI Camera Installed |
Posted: Tue Dec 27, 2005 11:04 am Post subject: |
Thanks Ibendlin I will give it a go. |
Dabhand16 Occasional Visitor
Joined: Dec 27, 2004 Posts: 21 Location: Bedfordshire
Posted: Fri Dec 30, 2005 11:28 am Post subject: |
Don't forget that the power cord will only fit one way, and you must squeeze the two buttons on either side of the plug to insert/remove the cord. _________________ Dabhand16
Bedfordshire
Mio 168 / Windows Pct PC 4.2 b14053 / Intel PXA255 / Kingston 512
TTN3 3.03 (427) / Sprite Premium 3.1.4 b2419 / CheckPOInt 3.2.0.0 / Digitools UK PostCode / GPSW Safety Camera Database |
Posted: Fri Dec 30, 2005 1:59 pm Post subject: |
Thanks for you reply, Yes i know i need to press the 2 sides of that, I've been using like this type of power cord long time
but this one is broken the silver small plate is out of handle, anyway i sent back to them let us see
Thanks _________________ Thanks
Mike
