Posted: Wed Nov 30, 2005 10:30 pm Post subject: Problems with GPS Slim 236 and GPS Viewer. Please help!
Hello!
I searched this forum and Google up and down trying to find a solution for my Holux GPSlim 236 but couldn’t find it anywhere. I cannot get GPS Viewer to find the GPS! Please, help me!
I have a Dell Axim x51v (with Windows Mobile 5.0) and received my Holux GPSlim 236 (serial 236-5430xxxx) two days ago.
So, here’s what I did: I installed the GPS Viewer and then I opened the Bluetooth Manager, selected the box “turn on Bluetooth” and “make this device discoverable to other devices”. Then I tap “new partnership” and the Axim finds the Holux GPS. I enter the 0000 passkey and then mark the checkbox “serial port” (I’ve tried marking and not marking this option but it doesn’t work either way). Then, I click finish, as there isn’t any other option. But according to the manual, I should select the option “connect to SSP Slave”, but I never got the chance to select this option. It never showed up to me and I couldn’t find it anywhere. All I can edit about Holux settings is the “serial port”, nothing more.
So, I go to GPS Viewer, select the baud rate 38400 and click Scan. All I get is “none” or “open failed”. I’ve tried with all baud rates but couldn’t get GPS viewer to find Holux. So, I clicked Start, Settings, System, GPS, to see what are the settings of my GPS according to Windows Mobile 5.0. At “Hardware GPS Setting” I only have the option to change the COM and the Baud Rate, but there is no baud rate of 38400 (the same as holux). I get either 33600 or 57600. Can this baud rate difference from Windows Mobile and Holux be the problem that is preventing GPS Viewer to find the Holux?
Please help me, I’ve tried everything, and the GPS seems to work fine, as the orange light starts to blink when it finds a satellite. Currently I don’t have any navigation software installed, as I’d like to get it to work before I buy one.
On the PDA when you go to:
Bluetooth Manager, New connect, explore a Bluetooth Device, Holux 236 the it should ask you to select "connect to SSP Slave" then you have added the device to the your PDA, then you can go ahead and pair the device, your BT manager might be different on your Dell but it should be simular. _________________ Regards
Steven Gourlay
Bike Pics!Bike Chat!Visit-Ullapool
Posted: Tue Dec 13, 2005 5:25 pm Post subject:
Having tried the software and the 236 with the Dell x50v running WM2005 I can confirm it will work, the folloing details what we did to get it up and running: (this assumes the device has not been setup in any way so I would sugest you delete any pairing etc that may exist between the PDA and the GPSlim unit first).
Go to Bluetooth Manager, Devices Tab, and select New Partnership, select Holux GPSlim236 press next
Enter pass key 0000 press next
Select Serial Port Service then press Finish.
In Bluetooth Manager select Com ports tab, select HoluxGPSlim236, select port value as Com7, tick the box for Secure connection (it is selected by default anyway), then press OK
Go to Start/ Settings/ System and select the GPS icon.
Set Program port to Com8
Set Hardware port to Com7
Baud to 33600
Access check box select Manage Automatic selected
Run up the GPS Viewer programe, set the Baud speed to 38400 and select Scan, The software should report Scan Com7....Found GPS! and Scan Com8....Found GPS!
Select Com8 from the list then press OK
Press the Start GPS Button and it should fire up and work.
Hope this gets you up and running - Mike
Posted: Wed Dec 14, 2005 10:07 pm Post subject:
Glad to hear its up and running, the strange thing is that if you only use TomTom then you don't have to mess around with the GPS icon, (is their GPS driver / BT interface better than the others?) any other software that needs access to the GPS data needs the GPS icon set-up (Holux and OS, plus no doubt others), had some fun getting it to work but worth it in the end - Mike
However, I still can't find GPS device in my Dell 51v PDA. Sometine I found it and worked well but 30 mins late it is disappeared. So please tell me how to solve it.
Posted: Mon Dec 19, 2005 4:19 am Post subject:
Victor, can you please supply more details, such as which software you are using when you cannot find the GPS, also where are you when the drop outs occur - Mike
I have just got my GPslim 236, and I am having the same problems. I cannot seem to get the 236 and GPS view to work together. I have a Qtek S110 running PPC 2003SE, so I cannot use the same advice as previously given. I am able to add the 236 as a new device, but that is as far as I go. I am also not too sure about the whole com / baud rate thing. Can any one help me please????
Posted: Sat Dec 24, 2005 4:50 pm Post subject:
Nick, When add the new device, you need to select SSP Slave, also have you tried to tap and hold on the GPSlim icon in the Bluetooth manager, from the pop-up screen select connect - Then you should be able to set the ports and speed (which is 38400), what software are you trying to configure it with? - Mike
Posted: Sat Dec 24, 2005 5:26 pm Post subject:
Nick, you select the SPP mode for the GPS unit during the set-up of the device in Bluetooth Manager, the icon if set-up correctly will say HOLUX GPSlim236: SPP slave, (spread over three lines) If for some reason it doens't I sugest you tap and hold the icon and select delete, if it does say this then select Connect.
If you deleted the connection as above then re-establish it again.
When the phone first finds the GPS device it might say retrieving services, then display the SPP as the option to select BEFORE pressing next.
As a matter of interest do you have to put the passKey 0000 into the Phone at any point?
and also what software are you going to use with it? - Mike
Holux GPSlim236 comes up, which I highlight, and then press next. It asks for the passkey, which I then enter 0000, then next.
A pop up window comes up labeled "Bluetooth Serial Port COM5" which has the following text "this bluetooth device supports serial port profile, would you like to create a bluetooth serial port for it?" I then press YES.
The Display window then comes up, and i then press finish, without changing the name.
When you talk about the bluetooth manager, where is this in mobile 2003?
Posted: Sat Dec 24, 2005 7:41 pm Post subject:
In the bottom RH corner of the today scren should be a bluetooth symbol, select that, and the Bluetooth My Shortcuts screen should appear, Tap and hold the GPSlim 236 icon then select conect, make sure the GPS unit is switched on and ready (wait ten seconds before trying the connect) you should then see two green arrows appear under the GPSlim 236 icon, then you can fire up the Holux software and select scan - this will identify where the GPS port is, then you will be up and running - Mike
that does not seem to be what is happening with my one.
I tap the bluetooth icon and bluetooth settings appear.
The first page has the options "Turn on Bluetooth, and make this device discoverable to other devices" at the bottom of the page is the options Mode, Device and com ports. I go to the devices page, and I tap and hold HOLUX GPSlim236. Pulldown for Edit and delete appear. I click on Edit, and the only thing that appears is a page where I can change the device name. That is all. No option to connect or anything. Under Com Ports, there is 2 options - New Outgoing Port, and New Incoming Port.
