Pocket GPS World :: View topic - Speed cams database
Speed cams database
furryfred
PostPosted: Thu Dec 22, 2005 11:37 pm    Post subject: Speed cams database Reply with quote
I have recently come to GPS and downloaded the present system as a trial - I don't regret it a bit.
On a mate's TomTom 300 with TomTom's speed cameras I see that there they have divided the cameras into 30, 40, 50 , 60, and 70 giving each of them their own icon on the screen.
The PocketGPSWorld database however only shows a camera on my TomTom 700 and as such doesn't give such a good warning as to the current speed limit. I assume that mine's working correctly - please tell me if it ain't!
Seeing that it is going to go "paid for" (which I don't condemn) would it be possible that the database can give the various speed limits for the cameras.
Keep up the good work!
Furry Fred
(a very very nice, handsome and generous gentleman who is really rather modest, shy and retiring!)
They didn't make many like him - and now they've lost the mould!
Eldar
PostPosted: Thu Dec 22, 2005 11:59 pm    Post subject: Reply with quote
It already does - you just need to install the correct files from the distribution.
furryfred
PostPosted: Fri Dec 23, 2005 1:43 am    Post subject: Reply with quote
Sorry to be thick
I had transferred the . ov2 and .bmp files from the "ov2 bmpfiles" folder and not from the "speed zones" folder. I now have done it and will have to drive past a friendly camera to test it!
Instructions are not very clear and could be improved Exclamation
Privateer
PostPosted: Fri Dec 23, 2005 12:26 pm    Post subject: Reply with quote
Hi furryfred,
Which instructions did you use?
There are some guides that should be read (in the following order):
Arrow The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
Arrow How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
Arrow How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
Once you have installed, set up, and used the PocketGPSWorld camera database for a while on your TomTom SatNav system. You may want to share and send in details of cameras yourself. You can do this by using the PocketGPSWorld POI Capture utility:
Arrow The PocketGPSWorld POI Capture utility.
You do not need the PocketGPSWorld POI Capture utility on your TomTom SatNav system in order to use the PocketGPSWorld camera database. However if you want to send in camera details then POI Capture makes the process of recording cameras much easier on TomTom Navigator and GO (original, 300, 500, and 700). At the moment POI Capture will not work with TomTom Rider, One, and mobile. This is for a technical reason, which we hope, will soon be rectified by TomTom.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Robert.
Garmin Camper 770 LMT-D
furryfred
PostPosted: Fri Dec 23, 2005 3:48 pm    Post subject: Reply with quote
Thanks for the information - very helpful at first glance.
I will have a look at it over Christmas substituting a brandy for each of the prescribed coffees. :D
Hopefully I will be concious when I get to the end but if I can't remember anything I will just have to repeat the prescription on Boxing Day! Rolling Eyes
<hic!>
Furry Fred
23.032 (12 Mar 25)
