Pocket GPS World :: View topic - Speed zoned Including Red Light & Temp locations on ttg5
leec
PostPosted: Tue Dec 20, 2005 2:54 pm    Post subject: Speed zoned Including Red Light & Temp locations on ttg5 Reply with quote
I am using the speed zoned files, but having done my second download an install i have noticed the speed zoned only contains Gatso, Mobile and Specs.
So if i want Red Light and Temp locations i assume i need to copy off the temp and redlight ov2 files from elsewhere in the zip file.
Where abouts will I find them in the zip. I am not quite confident in this aspect as i might put in the wrong files.
Thanks in advance
Lee
PostPosted: Tue Dec 20, 2005 3:00 pm    Post subject: Reply with quote
They are in the "ov2 bmp" folder. Smile
(Don't forget to copy across all the .bmp icon files with the same names as well - they are in the same folders as the ov2s, or there are some alternative/better ones in the "alternative bmps" folder)
leec
PostPosted: Tue Dec 20, 2005 3:04 pm    Post subject: Reply with quote
DOH! Embarassed
You just got there before me.
I just had another look and realised that.
Perhaps this could be mentioned in the instructions as it is one that is easy to miss for the begginer.
Thanks for your help
Lee
PostPosted: Tue Dec 20, 2005 3:08 pm    Post subject: Reply with quote
Don't worry mate. So many people cannot find them, that I've been campaigning to get these files duplicated in both folders. It would make the download a little bit bigger, but would save LOADS of forum bandwidth!
leec
PostPosted: Tue Dec 20, 2005 3:16 pm    Post subject: Reply with quote
Yes but only 33kb unzipped.
Deffo worth it. Even if it was mentioned in the instructions then at least you can look out for it.
I wrote a set of instructions today for what i did. I renamed the files as the names were so long I could not see the type of POI at the end as the Field is too small.
I will add in the bit about these 2 extra catagories tonight.
Lee
22.063 (19 Jun 24)
