Pocket GPS World :: View topic - Navman 3450 Jacket @ Ipaq 5550
vicky
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Navman 3450 Jacket @ Ipaq 5550 Reply with quote
Just wondered if someone could help with this,
Up till now I have been using an XDA with a Haicom GPS and TomTom2 Navigator,
I am now changing systems to an Ipaq 5550, I have ordered a Navman 3450 Jacket, and am planning to use it in the following setup
Loaded with TomTom Navigator2 UK and Navigator US, on a single 1Gb CF card (Both just fit).
Has anyone had any experience using the 5550 and the Navman Jacket (Are there any known problems with this setup), or with a large amount of maps loaded (Just about 1Gb).
Any help appreciated,
Victoria
gracar
By coincidence I'm emabarking on an almost similar path. I terminally broke my 3850 and have replaced it with a 5550. I can tell you that the system fires up OK with the Navman sleeve - software loads and I got a GPS fix. My next step is to sort out whether there are PC2003 issues and how I overcome them. My only concern, if I were you, would be the 1Gb storage and whether it would be accessible - there have been some problems with large SD cards for example.
Graham
Providing you're using a CF card and not MicroDrive, then I don't believe there will be any issues. There were initial problems with compatibility with the sleeve on the 5550, but this has now been recitified I believe, and Navman USA do say that the sleeve and SmartST Pro is compatible with 5400 and 5500 series iPAQ's.
There were also slow TTFF problems with the 3000 and 3400/3420 sleeves, but these have been rectified in the new 3450 sleeve. If you haven't read the 3450 review, then you can find it here
vicky
Hi Guys,
Thanks for your replies,
Yes my CF Cards are Cards Not Microdrives, I have a good supply of 1Gb CF Cards for use in my Work Camera so I can try several makes and snaffle the best for use in the Navman,
The TTFF does concern me, I would prefer to go for a more standard Bluetooth or Cable Setup, but I really need the large storage of a 1Gb CF card, as I drive across the US all the time, and don't really want the hassle of constant swapping of 256mb data chunks of the US map on SD cards
I suppose my other option would just be to get a standard CF adaptor jacket to hold the 1GB CF, and use a standard or Bluetooth GPS with it,
I will investigate that as well, anyone think that is a viable option.
Regards
Victoria
Victoria, I would go with a CF Jacket, and Bluetooth GPS, you'll get a much stronger signal with this set-up.
vicky
Hi All,
Again thanks for your comments on this,
I was able to cancel my order for the 3450 Jacket,
Instead decided to go for
Standard CF Jacket with Battery and a 2.4Gb Microdrive (Get all my world maps on that without ever having to swap card),.. and a Bluetooth GPS, lot easier when moving from vehicle to vehicle.
Looking forward to getting on the road to try it all out
Regards
Victoria
22.094 (25 Sep 24)
