DerekFKS85 Occasional Visitor
Posted: Thu Dec 15, 2005 9:26 am Post subject: CP6 camera warnings |
Since I successfully downloaded the camera database yesterday it is now working and picking up cameras. However it does not announce them properly.
It says:- "Aproaching in 0.2 mile 1 in 1 pocketgps_safetycamera_UK_SC" or somethins similar.
No nention of the unique number or the speed?
Sorry, need help again! |
Posted: Thu Dec 15, 2005 11:23 am Post subject: |
I've just re-laded the cmeras incase all the mucking about I did yesterday had some bearing on it. |
iankb Frequent Visitor
Joined: May 09, 2005 Posts: 283 Location: Reading, UK
Posted: Thu Dec 15, 2005 2:59 pm Post subject: |
The strange 'pocketgps ...' text comes from the name of the OV2 and BMP files. You need to rename them to 'Speed Cameras.*' - something which ALK fail to note on their support forum.
The speed is missing because the OV2 files still contain the '@' character that stops the following text from being spoken.
There is a bug in the initial release that causes the second half of a POI alert to be delayed until the beginning of the next alert, so making the alerts sound back to front. ALK have said that this will be fixed in their first patch. _________________ Ian
iPaq 2210
Globalsat BT-338
Seidio G2500 Amplified Vent Mount
CoPilot 6, GPS Tuner 4.2, Navio 3.01
BMW 330ci Sport |
Posted: Thu Dec 15, 2005 3:07 pm Post subject: |
Thanks again Ian.
Bit of a pest but at least I'm now being alerted to the cameras.
Roll on the fix. |
GregW Occasional Visitor
Joined: Nov 22, 2005 Posts: 32 Location: East Midlands, UK
Posted: Thu Dec 15, 2005 6:09 pm Post subject: |
Useful explanation - thanks.
I must admit I was a but underwhelmed with the speed camera alerts, having to look at the screen and work out from the text what the speed limit was. I had been thinking about reformatting the data to make it more sensible, but I'll probably wait for the patch now. |
Posted: Thu Dec 15, 2005 7:21 pm Post subject: |
The '@' sign problem was resolved with CP5 by PocketGPSWorld, by them providing a CP-specific version of the CSV files. Given that CP6 is supposed to be using the 'universal' TomTom OV2 files, they might not be so willing to provide an alternate copy.
I don't know whether ALK will be able to fix the '@' problem themselves within the next patch.
Currently, I use the TomTom DUMPOV2 and MAKEOV2 utilities to allow me to edit the OV2 file with Excel, to replace '@' by ' AT ', and the colon by space. _________________ Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport |
alix776 Pocket GPS Moderator
Posted: Thu Dec 15, 2005 7:54 pm Post subject: |
or you could use the alk poi .dat that is ont the alk site as a stop gap untill the patch is released _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
weirdfish Occasional Visitor
Posted: Thu Dec 15, 2005 8:14 pm Post subject: |
Quick question, can you rename the files after they're installed ir do you have to do it again. |
Posted: Thu Dec 15, 2005 11:27 pm Post subject: |
The files are deleted as soon as they have been imported - so you won't find anything to rename. You will need to reload them after renaming them.
However, first delete all of the AOPOI*.* files in the save directory, or you will end up with two copies. Deleting those files will remove all of your Custom POI's, so if you imported any others, you will need to reimport those again as well. _________________ Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport |
Posted: Thu Dec 15, 2005 11:45 pm Post subject: |
Cheers |
Posted: Fri Dec 16, 2005 12:14 am Post subject: |
Hmmm, I am only able to CP6 to install the files if I leave them as they are, if I change anything then CP6 opens as per normal and doesnt install them. |
Ako Regular Visitor
Posted: Fri Dec 16, 2005 12:55 am Post subject: |
IanKB wrote:
Quote: | Currently, I use the TomTom DUMPOV2 and MAKEOV2 utilities to allow me to edit the OV2 file with Excel, to replace '@' by ' AT ', and the colon by space. |
Ian,
When I do that, MAKEOV2 seems to be creating another column of double quotes before the name of the camera and then it doesn't work in copilot6. I've tried this in both csv format and txt format. When I did a DUMPOV2 of the newly created OV2 the extra column showed up. Any ideas?
Dave _________________ Holux231, XDAII Copilot 6, 1Gb Lexar SD Card |
Posted: Fri Dec 16, 2005 7:05 am Post subject: |
Ako wrote: | When I do that, MAKEOV2 seems to be creating another column of double quotes before the name of the camera and then it doesn't work in copilot6. |
The edited text file that you pass into MAKEOV2 should look something like this ...
Code: | ; Readable locations in pocketgps_uk_sc.ov2
; Longitude, Latitude, "Name"
-5.35235 , 50.20901 , "GATSO 1518 AT 60"
-5.34178 , 50.21175 , "GATSO 1972 AT 60"
-7.64851 , 54.33752 , "MOBILE 0773 AT 60"
Make sure that you haven't added any extra commas, or removed the double-quotes. The format of the commented-out column headings may also be important. _________________ Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport |
Bazzer Regular Visitor
Posted: Fri Dec 16, 2005 11:06 am Post subject: |
Quote: | There is a bug in the initial release that causes the second half of a POI alert to be delayed until the beginning of the next alert, so making the alerts sound back to front. ALK have said that this will be fixed in their first patch.
Nothing's changed from CP5 then ?? I reported this exact same problem when using CP5. What's been done to recitfy it since then. Absolutely SWEET F.A.!! Why doesn't that surprise me ?
In this respect, TomTom is 'Meelez' ahead (have they fixed this yet ??). After downloading the Camera Database, TomTom will clearly announce; "Warning, Gatso ahead, speed limit 30 miles per hour". None of the rediculous ' Approaching 1 of 1 in pont 2 of mile' nonsence.
I have kept reading the CoPilot forum in the hope that ALK would (after the shambles of CP5), have produced the killer application that it promised to be. But nothing that I have read so far would lead me to that conclusion.
Baz _________________ Garmin DriveSmart 61 LMT-D
TomTom Go 50 - Going in the BIN
TomTom Go 730 (RIP)
Garmin Montana 650
Garmin Oregon 45oT
Garmin Edge 1000
Tracklogs Digital Mapping |
Posted: Fri Dec 16, 2005 12:12 pm Post subject: |
I wondered when some grouch would turn up and ruin a perfectly adult post. |
