adamf Lifetime Member
![](modules/Forums/images/avatars/2404478364437ecc2a2344.jpg)
Joined: Jul 31, 2004 Posts: 410 Location: wolverhampton
Posted: Thu Dec 15, 2005 7:24 pm Post subject: nuvi camera database problems |
just got the nuvi 300 today downloaded garmin poi put the camera database on it says done but on the unit nothing there or if i aproach camera nothing any ideas????? |
drummer Frequent Visitor
Joined: Apr 08, 2004 Posts: 256 Location: Hampton, Middlesex, UK
Posted: Fri Dec 16, 2005 12:52 pm Post subject: |
Have you enable proximity warnings on the Nuvi? |
Posted: Fri Dec 16, 2005 1:36 pm Post subject: |
it says yes?? ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Superten Occasional Visitor
Posted: Fri Dec 16, 2005 2:30 pm Post subject: |
If I remember rightly, even with the proximity alert switched on, you are only warned if you have a route planned. If your using the Nuvi just as a map they don't show up. I could be wrong haven't had the alert on for a while. |
Posted: Fri Dec 16, 2005 2:52 pm Post subject: |
i was navigating at the time i loaded all the speeded zones ? |
KnightAzul Occasional Visitor
Posted: Fri Dec 16, 2005 4:53 pm Post subject: |
"you are only warned if you have a route planned."
Not so. I have the Nuvi 300 configured with 211 POI's for speed cameras with a 250 m proximity alert and it works both in "free roaming" mode and also when a route is planned.
My only gripe is that the alert is once only and not very intrusive.
It sounds like the POI's have not been loaded correctly. Can you seem them listed when you select the "Custom POI" section in the GUI on the Nuvi.
KnightAzul |
Posted: Fri Dec 16, 2005 8:51 pm Post subject: |
cant see that menu custom?? :o |
Posted: Fri Dec 16, 2005 9:27 pm Post subject: |
1. Switch the unit on
2. Select "Where to?"
3. Select "My Locations"
4. Select "Custom POIs"
You should see first 50 POI's listed. If not then they have not been loaded onto the device.
KnightAzul |
Posted: Fri Dec 16, 2005 9:46 pm Post subject: |
i will check for that thanks.. what do you think about these units??fast calculation leaves tomtom for dead not to kean on the voice and i cant get the text to speach to work...... |
Posted: Fri Dec 16, 2005 9:50 pm Post subject: |
ahh just specs in it?? all speeded zoned |
Skippy Pocket GPS Verifier
![](modules/Forums/images/avatars/7197988194d2507f52befb.jpg)
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Sat Dec 17, 2005 1:10 am Post subject: Re: nuvi camera database problems |
adamf wrote: | if i aproach camera nothing any ideas????? |
Drive faster?
TTS: I don't know if the 300 does TTS, I think it's only the 350. Anyone know?
(My god adamf, you have some number of sat nav systems!) _________________ Gone fishing! |
Posted: Sat Dec 17, 2005 2:09 am Post subject: |
The 300 does have TTS. You need to select the (TTS) voice in settings. |
Posted: Sat Dec 17, 2005 11:49 am Post subject: |
there is 2 languge options voice and text both set to english any more help please also what sort of thengs does yours say :o |
Shez Occasional Visitor
Posted: Sat Dec 17, 2005 2:34 pm Post subject: |
Hi Drummer.
Are you sure the Nuvi 300 has Text to speech? I can't find it on mine and thought it was only on the 350. |
newsagent Lifetime Member
Posted: Sat Dec 17, 2005 3:36 pm Post subject: |
Shez wrote: | Hi Drummer.
Can't find it on mine, thought it was only on the 350 also |
