Pocket GPS World :: View topic - bigger SD card
bigger SD card
bobnic6
PostPosted: Fri Dec 09, 2005 2:10 am    Post subject: bigger SD card Reply with quote
Hi all,
I just purchased TT Navigator 5 for PPC, and have activated the UK maps. I now find that the SD card it came on is not big enough (128Mb).
Is it safe to get a bigger card and just copy everything across? or does that destroy the activation?
Bob
schneid
PostPosted: Fri Dec 09, 2005 5:11 pm    Post subject: Reply with quote
I have no problem doing that with TT Navigator 5 USA on my iPaq. I can either copy the files over to the PC and back to the bigger card or reinstall the maps from the product CDs.
See my post above. I have no knowledge about pre-installed SD cards. That option is not available for the US. All my maps are on CDs.
PostPosted: Fri Dec 09, 2005 5:22 pm    Post subject: Reply with quote
Bob, welcome to the forum, use a card reader and make sure you select "show hidden files", in Windows Explorer, go to Tools then Folder options, view tab and select the radio button next to Show Hidden files.
Copy the whole lot accross onto the hard drive of the pc, make sure the PC has finished transfering the data then swap the SD card for the new larger one and copy the files back again, if you put the files into a folder on the PC make sure you copy them back so the files/ folder appear in exactly the same way on the new card - Mike
bobnic6
PostPosted: Fri Dec 09, 2005 9:06 pm    Post subject: Reply with quote
Thanks both,
Bob
schneid
PostPosted: Sat Dec 10, 2005 12:29 am    Post subject: Reply with quote
Well, did it work?
bobnic6
PostPosted: Sat Dec 10, 2005 4:31 pm    Post subject: New Card Reply with quote
Just waiting for the card to arrive,but I hve no doubts that it will work OK.
Bob
Mus
PostPosted: Mon Dec 12, 2005 7:14 pm    Post subject: Reply with quote
Mike
I also think it sensible to use a larger SD as I only have 1.5mb left and want add more POI's. I have a spare 512Mb and I need to copy the TT SD to my PC and then back to the spare SD. Problem is that it will not copy. It appears to although i get error messages (using copy & convert) and end result is that nothing appears on the PC folder except the folder name. I have tried sliding the protection lock without affect. I have also enabled 'view hidden folders'. I suspect I am missing something obvious!
Can you advise? I am running an XDA11 and Windows XP. Thanks
Murray
PostPosted: Mon Dec 12, 2005 8:03 pm    Post subject: Reply with quote
Murray, if you want to do this then use a card reader, not copy and convert which leads me to thinking you are trying this via active sync, if you are lucky this method might work but it will take ages, get an SD card reader for the PC if don't already own one - Mike
Mus
PostPosted: Thu Dec 15, 2005 10:51 am    Post subject: Reply with quote
Thanks Mike
Yes I tried it via activesync. It took ages and it did not work! Looks like a card reader.
Murray
Mus
PostPosted: Thu Dec 15, 2005 6:56 pm    Post subject: Reply with quote
Well I purchased a neat card reader, Dazzle Zio, and I still have problems. It did not like data.04 and Munich.bin (whatever that is). End result only 8MB of 119MB will copy! And yes I checked the SD was not 'locked'.
Any ideas anyone?
Mus - O2 XDA11
22.063 (19 Jun 24)
