Pocket GPS World :: View topic - Aerial ?
Aerial ?
cantgetlost
PostPosted: Thu Dec 15, 2005 12:22 am    Post subject: Aerial ? Reply with quote
If using add on external Aerial with I3, does the external aerial work alone or does the in built aerial do split duties?
RODTROTTER
PostPosted: Thu Dec 15, 2005 2:06 am    Post subject: Reply with quote
it acts like a booster both work at the same time
xander
PostPosted: Thu Dec 15, 2005 1:38 pm    Post subject: Reply with quote
Got mine off eBay - well worth getting - as I had a UV treated (Renault) windscreen and couldn't get a singel/lock-on with one. Did notice that rechargeable batteries got used up slightly faster though...
NoLCD
PostPosted: Thu Dec 15, 2005 10:22 pm    Post subject: Reply with quote
Most GPS aerials are active and require, typically a 5V, supply so will unfortunately use more power.
semaj
PostPosted: Sat Dec 24, 2005 6:53 pm    Post subject: Reply with quote
The antenna dont need to be mounted externally. Mine is in the rear window and works great .This is probably du to it not being treated or coated as was mentioned.
22.063 (19 Jun 24)
