bullterrier Occasional Visitor
Posted: Sun Dec 11, 2005 12:58 pm Post subject: tomtom 5 software with navman jacket 3000 & ipaq 3900 pr |
i have a navman jacket 3900 * a ipaq 3900 unit and trying to put tt5 software onto unit
i have got the software onto the unit & tried to setup tt5 and on the sat set up i have the disc turning but to no avail does it show any sat navs even outside for 20 mins nothing showing
please could anyone help me |
lbendlin Pocket GPS Staff
Posted: Sun Dec 11, 2005 2:33 pm Post subject: |
your jacket may be set to SiRF protocol. Reprogram it to NMEA _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
trevor.dowle Lifetime Member
Posted: Sun Dec 11, 2005 3:17 pm Post subject: Re: tomtom 5 software with navman jacket 3000 & ipaq 390 |
bullterrier wrote: | i have a navman jacket 3900 * a ipaq 3900 unit and trying to put tt5 software onto unit
please could anyone help me :( :( :?: |
Exactly the same set-up that I've got. Unfortunately I haven't got my kit with me at work at present, and I can't remember all the menu options. I'll bring it in tomorrow and if you still can't get started I'll post the directions for you... _________________ Regards
Trev Dowle
TomTom 730 T |
Posted: Sun Dec 11, 2005 3:34 pm Post subject: |
I have the same kit and I do have mine with me. Do you have the Navman 3.1.6 driver installed? Configure the GPS as 'Other NMEA GPS', set the baud rate to 57600 and select Navman driver as the port. This works on my 3970 with Navman SE sleeve with the firmware update. Tomtom version is 5.420. _________________ Tim |
Posted: Sun Dec 11, 2005 8:19 pm Post subject: reply |
i have it set to other nmea and set the baud rate to 57600
and still got the problem
Please could you help me further |
Posted: Sun Dec 11, 2005 8:31 pm Post subject: |
I can try. It took me ages to get a fix. Was Navman Driver at the top of the list of the Comport options? _________________ Tim |
Posted: Sun Dec 11, 2005 9:11 pm Post subject: |
yes it was |
Posted: Sun Dec 11, 2005 9:17 pm Post subject: tim what is the firmware update |
Posted: Sun Dec 11, 2005 9:21 pm Post subject: |
Have you any other GPS software you can try? Navman have GPSInfo which will tell you if the GPS is actually receiving anything. Get it here. _________________ Tim |
Posted: Sun Dec 11, 2005 9:31 pm Post subject: Re: tim what is the firmware update |
bullterrier wrote: | tim what is the firmware update |
It's an update for the later Navman sleeve, the one with the external antenna socket on the side. If you need it, you can get it here. _________________ Tim |
Posted: Sun Dec 11, 2005 10:06 pm Post subject: tim i have tried the gps info download |
the info is showing nothing at all
my tomtom 5 on the gps is set at 57600 and the disc is moving around but showing no sats |
Posted: Sun Dec 11, 2005 10:48 pm Post subject: tom i have tried other ways |
Tom
I have tried to go into start-settings-connections- and it only shows beam & connections no gps at all is this where i have the problem ? |
Posted: Sun Dec 11, 2005 11:30 pm Post subject: |
Tom? You got two people helping you?
Anyway, when I run GPS info it shows two sats (I'm indoors) and doesn't have a clue where I am! At the bottom of the screen it shows
Installed Drivers:
Navman
and
Active: Navman (Com4; 57600)
Below that it shows the receiver software version of 2.3.7
Does yours have anything like this? Try a soft reset first. _________________ Tim |
Posted: Sun Dec 11, 2005 11:34 pm Post subject: this is what it shows |
installed drivers:navman
active navman (com4: 57600)
reciever sw version:
2.1.1 mo1325 bw a navman ipaq 2.1.0 |
Posted: Sun Dec 11, 2005 11:37 pm Post subject: |
It sounds as though yours is the older sleeve. Does it have an external antenna socket? _________________ Tim |
