Pocket GPS World :: View topic - tomtom 5 software with navman jacket 3000 & ipaq 3900 pr
bullterrier
PostPosted: Sun Dec 11, 2005 12:58 pm    Post subject: tomtom 5 software with navman jacket 3000 & ipaq 3900 pr Reply with quote
i have a navman jacket 3900 * a ipaq 3900 unit and trying to put tt5 software onto unit
i have got the software onto the unit & tried to setup tt5 and on the sat set up i have the disc turning but to no avail does it show any sat navs even outside for 20 mins nothing showing
please could anyone help me Sad Sad Question
PostPosted: Sun Dec 11, 2005 2:33 pm    Post subject: Reply with quote
your jacket may be set to SiRF protocol. Reprogram it to NMEA
trevor.dowle
PostPosted: Sun Dec 11, 2005 3:17 pm    Post subject: Re: tomtom 5 software with navman jacket 3000 & ipaq 390 Reply with quote
please could anyone help me :( :( :?:
Exactly the same set-up that I've got. Unfortunately I haven't got my kit with me at work at present, and I can't remember all the menu options. I'll bring it in tomorrow and if you still can't get started I'll post the directions for you...
Regards
Trev Dowle
TomTom 730 T
Tim Buxton
PostPosted: Sun Dec 11, 2005 3:34 pm    Post subject: Reply with quote
I have the same kit and I do have mine with me. Do you have the Navman 3.1.6 driver installed? Configure the GPS as 'Other NMEA GPS', set the baud rate to 57600 and select Navman driver as the port. This works on my 3970 with Navman SE sleeve with the firmware update. Tomtom version is 5.420.
Tim
bullterrier
PostPosted: Sun Dec 11, 2005 8:19 pm    Post subject: reply Reply with quote
i have it set to other nmea and set the baud rate to 57600
and still got the problem
Please could you help me further
Tim Buxton
PostPosted: Sun Dec 11, 2005 8:31 pm    Post subject: Reply with quote
I can try. It took me ages to get a fix. Was Navman Driver at the top of the list of the Comport options?
Tim
bullterrier
PostPosted: Sun Dec 11, 2005 9:11 pm    Post subject: Reply with quote
yes it was
bullterrier
PostPosted: Sun Dec 11, 2005 9:17 pm    Post subject: tim what is the firmware update Reply with quote
Tim Buxton
PostPosted: Sun Dec 11, 2005 9:21 pm    Post subject: Reply with quote
Have you any other GPS software you can try? Navman have GPSInfo which will tell you if the GPS is actually receiving anything. Get it here.
Tim
Tim Buxton
PostPosted: Sun Dec 11, 2005 9:31 pm    Post subject: Re: tim what is the firmware update Reply with quote
It's an update for the later Navman sleeve, the one with the external antenna socket on the side. If you need it, you can get it here.
Tim
bullterrier
PostPosted: Sun Dec 11, 2005 10:06 pm    Post subject: tim i have tried the gps info download Reply with quote
the info is showing nothing at all
my tomtom 5 on the gps is set at 57600 and the disc is moving around but showing no sats
bullterrier
PostPosted: Sun Dec 11, 2005 10:48 pm    Post subject: tom i have tried other ways Reply with quote
Tom
I have tried to go into start-settings-connections- and it only shows beam & connections no gps at all is this where i have the problem ?
Tim Buxton
PostPosted: Sun Dec 11, 2005 11:30 pm    Post subject: Reply with quote
Tom? You got two people helping you? Laughing
Anyway, when I run GPS info it shows two sats (I'm indoors) and doesn't have a clue where I am! At the bottom of the screen it shows
Installed Drivers:
Navman
and
Active: Navman (Com4; 57600)
Below that it shows the receiver software version of 2.3.7
Does yours have anything like this? Try a soft reset first.
Tim
bullterrier
PostPosted: Sun Dec 11, 2005 11:34 pm    Post subject: this is what it shows Reply with quote
installed drivers:navman
active navman (com4: 57600)
reciever sw version:
2.1.1 mo1325 bw a navman ipaq 2.1.0
Tim Buxton
PostPosted: Sun Dec 11, 2005 11:37 pm    Post subject: Reply with quote
It sounds as though yours is the older sleeve. Does it have an external antenna socket?
Tim
