Pocket GPS World :: View topic - ps/ to usb convertion
MGBc
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: ps/ to usb convertion Reply with quote
not sure if the answer to this might be similar to the one for "Topic: Haicom 202e usb - ipaq conversion help" but I wondered if it was OK to make a lead up to convert a Haicom 203e with a ps/2 plug to USB, and if so can anyone tell me which of the centre USB connections the Tx and Rx connections go to.
Pc-Mobile
NO.
Not just PS2/USB plug. You also need a USB>Serial converter in between.
Pc-Mobile
http://pc-mobile.net/gps.htm
MGBc
it's a female ps/2 to USB I need not not a 9 pin din to USB, which is all that seems to be available on http://pc-mobile.net/gps.htm
Pc-Mobile
You did not get it.
It will not work.
It is not just the connector physically.
Save yourself time and find another solution.
Pc-Mobile
DavidW
The HI-203E is a serial GPS with a PS/2 connector. Haicom sell a USB cable for it - see here. You can't just connect a USB plug (the cable contains a 'lump' which contains a USB to serial chip).
You use HI-202E drivers with this cable.
k_c_tao
PostPosted: Tue Jun 15, 2004 8:12 pm    Post subject: Re: ps/ to usb convertion Reply with quote
Pc-Mobile wrote:
You did not get it.
It will not work.
exactly, there has to be a kind of signal convertor in between, so it will convert serial signal to usb signal.
