Pocket GPS World :: View topic - Can not find GPS with ttn5
riz
PostPosted: Fri Dec 09, 2005 6:32 pm    Post subject: Can not find GPS with ttn5 Reply with quote
have ttn5 working on my xda exec but it wont find the gps can some one help
PostPosted: Fri Dec 09, 2005 6:49 pm    Post subject: Reply with quote
Riz, Welcome to the forum, go to settings, Bluetooth select the COM ports tab and then new Outgoing Port, on the next window select the GPS unit then next, finally use the dropdown box to select a com port (I used COM4) this worked. Then fire up TT select the prefferences, other BT GPS Device and it should be OK - make sure you have a clean line of sight to the sky first (not indoors) - Hope this helps - Mike
lbendlin
PostPosted: Fri Dec 09, 2005 6:52 pm    Post subject: Reply with quote
in addition make sure your GPS talks NMEA. TTN5 doesn't understand SiRF any more
Lutz
TomTom/TeleAtlas NAVTEQ
riz
PostPosted: Fri Dec 09, 2005 7:14 pm    Post subject: Reply with quote
is tells me that com port could not be created
riz
PostPosted: Fri Dec 09, 2005 7:30 pm    Post subject: Reply with quote
got it it working on com 8 thanks
22.094 (25 Sep 24)
