riz Occasional Visitor
Posted: Fri Dec 09, 2005 6:32 pm Post subject: Can not find GPS with ttn5 |
have ttn5 working on my xda exec but it wont find the gps can some one help |
Posted: Fri Dec 09, 2005 6:49 pm Post subject: |
Riz, Welcome to the forum, go to settings, Bluetooth select the COM ports tab and then new Outgoing Port, on the next window select the GPS unit then next, finally use the dropdown box to select a com port (I used COM4) this worked. Then fire up TT select the prefferences, other BT GPS Device and it should be OK - make sure you have a clean line of sight to the sky first (not indoors) - Hope this helps - Mike |
lbendlin Pocket GPS Staff
Posted: Fri Dec 09, 2005 6:52 pm Post subject: |
in addition make sure your GPS talks NMEA. TTN5 doesn't understand SiRF any more _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Fri Dec 09, 2005 7:14 pm Post subject: |
is tells me that com port could not be created |
Posted: Fri Dec 09, 2005 7:30 pm Post subject: |
got it it working on com 8 thanks |
