jguiver Regular Visitor
![](modules/Forums/images/avatars/98435187643624435c0bcc.jpg)
Joined: Jul 26, 2005 Posts: 65 Location: No valid GPS Signal!
Posted: Thu Dec 08, 2005 7:22 pm Post subject: Speed Warnings |
I have the speed cameras installed on the latest version of TT5.
In addition, what I would like is something compatible with TT5 that will alert me when my speed exceeds nn mph. Presumably this is possible, since my GPS knows how fast I am going. It would need to either integrate with TT, or be capable of running at the same time.
Does anyone know whether such a thing exists?
Thanks in advance. _________________ HP rx5935, 2GB SD Card, TTN 6.1, GPSDash |
argosafe Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_matrix_012.jpg)
Posted: Thu Dec 08, 2005 7:27 pm Post subject: |
The only thing I know of is the capacity for TTN to revert to a Navigation rather than a map display when a prescribed speed limit is exceeded. See disp[al/hide map, you then get three options, one of which allows a display change over aspeed you set.
This is how I do it and my display changes above 73 mph.
a sound alert would be useful I suppose... _________________ XDA Orbit (the best so far)
XDA 2S
IPAQ 5455
IPAQ 4700
Globalsat Bt 338
Globalsat 337 CF reciever
Navman sleeve
256Mb Kingston CF Card
Lexar 512Mb card
Toshiba 1Gb SD card |
Posted: Fri Dec 09, 2005 11:56 am Post subject: |
Good idea - I'll do that. Perhaps someone will come up with a visual/audible warning add-in for Tomtom.
As I last resort, I suppose I could use that dial with the pointy needle in my dashboard................... _________________ HP rx5935, 2GB SD Card, TTN 6.1, GPSDash |
Mystery Regular Visitor
![](modules/Forums/images/avatars/145186102042be746720d66.jpg)
Posted: Fri Dec 09, 2005 1:47 pm Post subject: |
A good program for speed limiting is Speed Sentry it is not expensive ($11.25) and has many other great uses like logging distances etc for claiming mileage from work etc. To go with this you would need GPSGate ($9.95). This allows the use of two (or more if required but more expensive) programmes to use 1 GPS device.
I use both and find them great
for Speed Sentry :
http://www.pocketgear.com/software_detail.asp?id=16855
for GPSGate:
http://franson.com/gpsgate/
Take a look _________________ Mystery
O2 XDA Orbit 2
TTN6.030
