Pocket GPS World :: View topic - Wired Tomtom GPS -> Mini-USB?
Geir_Andersen
PostPosted: Mon Dec 05, 2005 4:45 pm    Post subject: Wired Tomtom GPS -> Mini-USB? Reply with quote
I've got a new Qtek 9100, which have a mini-usb connector.
Is it possible to wire my Tomtom GPS to the mini-usb connector?
I guess only Tx & RX could be connected, because mini-usb is 3.3V.
Any advis would be much appreciated!
PostPosted: Tue Dec 06, 2005 4:33 am    Post subject: Reply with quote
DO NOT ATTEMPT THIS! You will destroy both the receiver and the phone.
USB is NOT compatible with RS232.
Pc-Mobile
PostPosted: Tue Dec 06, 2005 3:20 pm    Post subject: Reply with quote
You cannot connect any wired GPS.
BT is the only way to connect a GPS for your PDA.
Pc-Mobile
http://pc-mobile.net/gps.htm
Geir_Andersen
PostPosted: Tue Dec 13, 2005 3:39 pm    Post subject: Reply with quote
Ok, but if I use a RS232 to USB converter it wouldn't fry anything right??
Pc-Mobile
PostPosted: Tue Dec 13, 2005 5:23 pm    Post subject: Reply with quote
There is no such thing! for your particular PDA.
Pc-Mobile
Geir_Andersen
PostPosted: Wed Dec 14, 2005 12:37 pm    Post subject: Reply with quote
A general RS232 to USB converter can be bought in most computer stores!
My PDA has a mini USB converter, so it should be possible to:
Wire the TX and RX wires from the GPS, connect then to the Converter, attach a USB to Mini USB wire, and connect to the PDA!(?)
Pc-Mobile
PostPosted: Wed Dec 14, 2005 3:00 pm    Post subject: Reply with quote
Do not waste time.
It will not work.
That was why the statement "there is no such thing".
Pc-Mobile
Geir_Andersen
PostPosted: Wed Dec 14, 2005 3:25 pm    Post subject: Reply with quote
Do not waste time.
It will not work.
Would you mind explain WHY?
PostPosted: Wed Dec 14, 2005 4:02 pm    Post subject: Reply with quote
In a USB connection you have a client and a host (the host has the logic to drive the communication. your PDA is a CLIENT, the GPS is a CLIENT. You cannot connect two USB clients together, except if you have a special USB Host cable (which has the driving logic integrated into the cable)
If you had a Toshiba or Asus PocketPC you could enable USB Host on the PDA, and could connect a USB GPS (maybe - you may still need special drivers on the PPC side)
As said before RS232 adn USB signaling and voltage levels are completely different.
22.063 (19 Jun 24)
