Pocket GPS World :: View topic - PocketGPSWorld.com launch POICapture for TomTom GO
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
forky
PostPosted: Mon Dec 05, 2005 1:07 pm    Post subject: Reply with quote
I have poicapture fully installed and passed a mobile camera which I recorded. I am now ready to upload the file but when I look at the pocketgpscameras .ov2 file it shows as size=0. Does this mean it hasn;t captured the camera Question Question
Garmin Nuvi 2699lmt
Samsung Galaxy S23 Ultra. (EE)
PostPosted: Mon Dec 05, 2005 3:17 pm    Post subject: Reply with quote
That is possible if the map reload hasn't worked. Can you please poke the reset hole, and then try again?
(we're waiting for a fix from TomTom)
forky
PostPosted: Mon Dec 05, 2005 3:31 pm    Post subject: Reply with quote
Done that Lutz and still the same.
Has anyone else got the same problem
Garmin Nuvi 2699lmt
PostPosted: Mon Dec 05, 2005 3:40 pm    Post subject: Reply with quote
can you try to add a POI to the "PocketGPSCameras"category via the TomTom GO interface?
forky
PostPosted: Mon Dec 05, 2005 3:45 pm    Post subject: Reply with quote
apologies for being a bit dumb but could you explain please
Garmin Nuvi 2699lmt
DerekG
PostPosted: Mon Dec 05, 2005 4:26 pm    Post subject: Actual POI Snapshot Reply with quote
Lutz,
While you are on the subject, can you tell me where in the sequence of tapping icons is the actual GPS reading taken (not the POI written to file)? For instance, is it after the "Capture POI" icon on menu 1 or is it only after all the desions have been made and the last icon is tapped? I'm sure you realise this can affect the number of misplaced recordings, but I'm just interested how I need to behave to get more accurate recordings?
Privateer
PostPosted: Mon Dec 05, 2005 4:35 pm    Post subject: Reply with quote
Hi DerekG,
POI Capture uses the longitude and latitude at the time that you press the POI Capture button on the menu.
POI Capture remembers that information (and your direction of travel) and waits for you to add the other attributes for the site (camera type, speed, and finally this/other side). Once you’ve added all those attributes POI Capture records them together with longitude and latitude and compass bearing in the PocketGPScameras.ov2 file.
Robert.
Garmin Camper 770 LMT-D
DerekG
PostPosted: Tue Dec 06, 2005 4:34 am    Post subject: Reply with quote
Robert,
Thanks for the "heads up" on exactly when the timings are taken.
Lutz,
I've just discovered (the hard way) that the precedence for processing the SDK menu .cap files is based on time order only, not date and time as you'd expect (see earlier post). As you say, a bit embarrassing for some TomTom programmer (somewhere)?
Thanks to you both for your help.
Derek
forky
PostPosted: Thu Dec 08, 2005 8:59 pm    Post subject: Reply with quote
Cannot add poi to pgpscameras category via tt interface as you asked
Garmin Nuvi 2699lmt
Boxbrownie
PostPosted: Wed Jan 04, 2006 3:29 pm    Post subject: 5.4 version yet? Reply with quote
Hi there, any news on the version that will work with 5.4 yet?
Cheers mateys.....
best regards David
thedon
PostPosted: Fri Jan 06, 2006 12:33 am    Post subject: Mobile Phone icon moved? Reply with quote
Firstly thanks for creating such a great application - I'll be submitting confirmation of all my local camera's, together with speed and direction later this month.
My only complaint, is that the Mobile Phone icon I use to initiate the handsfree kit has moved to menu page 4. I know it's a very minor thing, but I'd really like to have it on page 1.
Is there any easy way to do this, and am I right in thinking one of the icons on page 1 is the most frequently used one? (I currently have 2 Add Favourite icons, one on page 1, and one on page 3).
Hope someone can help.
Don.
Privateer
PostPosted: Fri Jan 06, 2006 4:04 pm    Post subject: Reply with quote
Hi thedon,
Glad you like the application, we look forward to receiving your confirmation of your local cameras. Thumbs Up
We had to create generic menus for each TomTom product that would suit the majority. However everybody has his or her own requirements for each page of the menu. Fortunately the TomTom menus are easy to customise to your own specific requirements.
You should have a folder on your TomTom unit that is called "SdkRegistry" and in that folder you will have the file that defines the menu, which is called tomtom.mnu.
Before you go any further, make sure that you at least have a backup of the original tomtom.mnu file, but a full back up of your application and storage card is recommended.
Use Microsoft Notepad to open the tomtom.mnu file. The code will contain a line, which refers to the mobile phone (call number option):
Code:
TASK_DIAL_POI
Just swap two menu options around. Save the new menu and copy it back to your TomTom unit.
Robert.
prisci14
PostPosted: Wed Mar 01, 2006 10:05 pm    Post subject: Reply with quote
Just to say guys what a fantastic site this is!!Very informative.May i ask a quick question which may sound nooby,but can i use poi capture on my tom tom one v5.41.If so which poi capture can i use?Any guidance on this is gratefully received.Thanx in advance Smile
PostPosted: Wed Mar 01, 2006 10:24 pm    Post subject: Reply with quote
try 1.03G - the older version will most probably not work.
Any reason why you don't upgrade to 5.420 ?
worthingsaxovtr
PostPosted: Wed Mar 22, 2006 10:43 pm    Post subject: Reply with quote
does this work on update 5.44
Page 7 of 9
