phinic20 Occasional Visitor
Posted: Sun Dec 04, 2005 7:30 pm Post subject: pci download |
hi everybody i have just bought myself the new tomtom one very good price from argos as recomend by this board
my problem is does anybody have a how 2 on the how to download the pci information so that i can use the tomtom to detect the damm speed cameras. i have tried to down load streight to my pc and copy it over to the card but even when it has done this i still caint get it to come on through the tomtom
any help very much appreciated |
westentertainer Frequent Visitor
![](modules/Forums/images/avatars/99943476543e3e96725b15.gif)
Posted: Sun Dec 04, 2005 7:44 pm Post subject: |
ok download cameras save to folder on pc put card in card reader and open great britain maps on card
now copy and paste the cameras to that opened folder
replace card in ppc and go to enable points of interest and enable these cameras with a tick ,this is the simple way to do it |
Posted: Mon Dec 05, 2005 11:47 am Post subject: |
when you say download when i download i then extract the zip information. this then creates tow folders which of these do i need to copy to the great britain folder.
sorry for not getting this but been really struggling all weekeend with this would really appreciate a step by step if you have one
many thanks
Philip |
fwor Occasional Visitor
Posted: Mon Dec 05, 2005 12:44 pm Post subject: |
THAT HELPS A LOT THANKS, JUST ONE QUESTION WHEN I HAVE DOWNLOADED THE FILE AND UNZIPPED IT I GET A FILE CALLED GO WHEN I OPEN THIS I HAVE TWO MORE FOLDERS POI CAPTURE AND SDK REGISTRY WHAT DO I NEED TO COPY FROM THESE FOLDERS INTO MY MAP FOLDER ON THE TOM TOM ONE FOLDER WHEN I OPEN THE POI CAPTUER FILE MIT THEN GIVES ME THREE MORE FILES ONE CALLED ICONS ONE CALLED POI CAPTURE AND ONE CALLED DIXON . DO I JUST NEED TO GO INTO THE ICONS FILE AND COPY THESE OVER AND IF SO WHAT DO I NEED TO DO WITH THE SDK REG FILE WHEN I OPEN THAT THERE ARE FOUR FILES IN WHICH OF THESE NEEDS TO BE COPIED TO THE MAP FOLDER.
SORRY FOR SOUNDING SO THICK BUT HAVE BEEN TRYING ALL W/E AND I KNOW I SHOULD BE GETTING THIS BUT JUST NOT PLENTY OF HELP VERY VERY MUCH APPRECIATED |
Posted: Mon Dec 05, 2005 3:59 pm Post subject: |
any body got any more info please all help gratefull |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Mon Dec 05, 2005 4:35 pm Post subject: |
As others have said, don't worry about the other files. Just follow the instructions and you will be okay.
All you should be copying to your GO is the .ov2 files and .bmp files that you want. Nothing else.
The other things are for an application to log camera locations, don't worry about those. |
![](modules/Forums/images/avatars/32928398450ec149ec6abd.gif)
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Mon Dec 05, 2005 4:40 pm Post subject: |
Hi phinic20,
Belated to the forum!
There are some guides that should be read (in the following order):
The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Garmin Camper 770 LMT-D |
Posted: Mon Dec 05, 2005 4:56 pm Post subject: |
Hi phinic20,
MarkHewitt wrote: | The other things are for an application to log camera locations, don't worry about those. |
I’m not sure whether the TomTom One can currently run POI Capture, probably not if the TomTom One is running software version 5.420.
However we do want as many people to install POI Capture as possible. Then when you pass a camera site, please capture it and then send in the details using the following URL:
http://www.pocketgpsworld.com/poicapture.php#submit
Posted: Mon Dec 05, 2005 5:24 pm Post subject: |
thanks for all the help still struggling a bit which are the o.v2 files i have found the icons folder do i need to download all of that as well as the db files |
Posted: Mon Dec 05, 2005 6:25 pm Post subject: |
Each .OV2 file is a database file. An .OV2 file can be a full category or a sub-category speed-zoned database.
For every .OV2 file you place in the map folder, you will need to place an identically named .BMP file (in the same map folder) to show the location of that type of .OV2 file on the screen.
Posted: Mon Dec 05, 2005 8:11 pm Post subject: |
when i open the go file once it has been extracted i get folders one poi capture one sdk registry in which of these are the 0.2v files as i caint seem to find them pleeessseee help |
Posted: Mon Dec 05, 2005 8:49 pm Post subject: |
still caint get this to work would anyone be willing to give me a call on the old moby to help i know its probobly something stupid that iam either doing or not doing
thanks |
Posted: Mon Dec 05, 2005 9:47 pm Post subject: |
done it thanks for everyones help very much appreciated. |
BoPeep Pocket GPS Moderator
![](modules/Forums/images/avatars/187616595350e6d8f554eed.gif)
Joined: 14/03/2003 22:46:42 Posts: 953 Location: Oxfordshire, England, United Kingdom
Posted: Mon Dec 05, 2005 11:41 pm Post subject: |
Hi phinic20,
to the forum.
I'm glad you got everything sorted in the end - well done.
I know you only did it once so it's probably unlikely to happen again anyway, but could I make a polite request that you refrain from posting in capital letters in future as it appears as if you are shouting at people, and also makes the post extremely difficult to read.
In fact a lot of people tend to skip posts which are solely in capital letters for the above reason, so it actually has the opposite effect of attracting attention to the post! ;-)
Bo Peep. _________________ TomTom 730
HTC Desire - Co Pilot Live Premium (Europe) |
