RicoBunyon Occasional Visitor
Posted: Fri Dec 02, 2005 7:54 pm Post subject: |
Anyone got problems with Fatal Exceptions after applying the upgrade? I went from the vanilla Nav5 to the latest on my Palm Tungsten T5. I had an exception when starting Nav for the first time after the upgrade, so reset the PDA and it then fired up ok. Since then, it just won't start up - I always get a Fatal Exception and have to reset the PDA.
I'm going to have to try to rollback to the original version just so I can use the thing! :x |
Peter Kessler Regular Visitor
Joined: 08/10/2002 09:12:29 Posts: 129 Location: United Kingdom
Posted: Sun Dec 04, 2005 1:14 am Post subject: |
Aniskhan, I have the same backlight problem with 5.1. Can you tell me where to get the fix? Many thanks |
panget Occasional Visitor
Posted: Sun Dec 04, 2005 10:53 am Post subject: cannot switch to north american maps after installing 5.21 |
i've had problems running tomtom 5 on my o2 xda2s, tomtom kept shutting down as soon as it tries to display an address on the map. i've gone to my old ipaq h5550 and it worked fine.
now the new patch 5.21 seem to have fixed that problem and i can now run tomtom 5 on my xda. the new problem is i can no longer switch to my north american maps. my usa and canada maps dont even display on the list of maps after i tap on the "switch map" icon (same problem on my ipaq). i'm going to the usa in two weeks and i would like to be able to drive around with my tomtom in use.
any help is much appreciated. |
mcwarre Regular Visitor
Posted: Sun Dec 04, 2005 11:05 am Post subject: |
When I try to use the exe file it tries to install activesync first (I have teh latest build of 4.1 from M$); if I cancel it the update will not run.
I downloaded the .zip file and copied it to my sd card. Installed from there and it mentions that it will have to remove my previous version (5.1). It tries to and then fails.
I have a K-Jam but it seems that I will probably have to hard reset to fresh install; as it seems there are negligible benefit then I can't be a*sed... |
AnisKhan Occasional Visitor
Asghar Occasional Visitor
Posted: Sun Dec 04, 2005 9:24 pm Post subject: |
Do the current Favourites stay after the upgrade to 5.21, or would I have to enter them again.
Currently using v5.0. |
lbendlin Pocket GPS Staff
Posted: Sun Dec 04, 2005 9:46 pm Post subject: |
Favorites stay intact. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun Dec 04, 2005 10:38 pm Post subject: |
lbendlin wrote: | Favorites stay intact. |
Thanks for the info. |
beldaal Occasional Visitor
Posted: Sun Dec 04, 2005 11:09 pm Post subject: Re: cannot switch to north american maps after installing 5. |
panget wrote: | ... the new problem is i can no longer switch to my north american maps. my usa and canada maps dont even display on the list of maps after i tap on the "switch map" icon (same problem on my ipaq). |
This sounds a bit to me as though you're not (or no longer) licensed for the US maps. Was your activation normal? Or did you do something else ............
NL |
Scotch Occasional Visitor
Posted: Mon Dec 05, 2005 12:01 pm Post subject: |
I for one would like to thank TomTom for their fantastic software. Before I bought this application my knowledge of PDAs and the Internet was almost zero. I now have a knowledge of creating directories and moving files around. Creating backups of the PDA before daring to perform any upgrades and even posting to newsgroups.
Without TomTom I would never have discovering this fascinating hobby.
I now have a fully working system and look forward to the next upgrade.
A very happy pensioner!
Dave |
dunos Regular Visitor
Posted: Mon Dec 05, 2005 12:11 pm Post subject: |
Scotch wrote: | I for one would like to thank TomTom for their fantastic software. |
Hehe, well, I am glad someone is happy!  _________________ http://www.durrans.com/cardspeed/ - Flash Card Speed Tests
http://www.durrans.com - In the beginning, there was nothing, which exploded. |
Posted: Mon Dec 05, 2005 2:07 pm Post subject: Re: cannot switch to north american maps after installing 5. |
beldaal wrote: | panget wrote: | ... the new problem is i can no longer switch to my north american maps. my usa and canada maps dont even display on the list of maps after i tap on the "switch map" icon (same problem on my ipaq). |
NL |
my usa maps wont even show up in the list so that i can re-activate it. |
Posted: Mon Dec 05, 2005 3:10 pm Post subject: |
starting with 5.100, TTN 5 does no longer read v4 maps.
Try setting the last line of the PNA file to 567 _________________ Lutz
explorer2k Occasional Visitor
Posted: Mon Dec 05, 2005 10:49 pm Post subject: |
First: Thank you all for your tips.
So, I was using Tomtom 5.1 fine on my PPC-6600
Then I got the 6700.
I installed 5.1 manually and it worked fine loading my maps, just wont woirk with my GPS.
When 5.21 came out, I did a full reset, installed 5.1>5.1>5.21
Now, it will not read my maps.
I have tried to change the 567, but still no luck.
Any ideas on why 5.1 did, but 5.2 wont?
Thanks |
Posted: Mon Dec 05, 2005 11:38 pm Post subject: |
No, 5.0 did. 5.1 already didn't/doesn't. Ask TomTom why. Their reply will be "because we are old and we need the money". Wait, that was John Cleese... _________________ Lutz
