mudpool Occasional Visitor
Posted: Sun Nov 13, 2005 8:04 pm Post subject: Is this true or not !! ? |
Ok this may be an urban myth but I am hoping that the hugely knowledgeable people on here will be able to answer this straight away. I could lose £50 over this.
Someone has told me that if you turn on a tomtom on an aircraft, it will work and you will be able to see how fast you are moving !!
I have bet £50 that this is not correct, surely it cant be ?? you would not be able to latch on to a satellite through the aircraft roof would you ?
If I win this bet through someone giving me conclusive evidence I am prepared to split the winnings 50/50 !!!!
Help !! _________________ My favourite site of the week ! www.satnavvoices.com |
Antoeknee Lifetime Member
Posted: Sun Nov 13, 2005 8:37 pm Post subject: |
There have been posts on some forums where people have done this and its worked. |
Andy_P Pocket GPS Moderator
Posted: Sun Nov 13, 2005 8:40 pm Post subject: |
You should have done a search before you bet.....
Have a look HERE
or HERE
Can I have your mate's address so I can share his winnings  |
Unplugged Regular Visitor
Joined: Jul 31, 2005 Posts: 142 Location: Northampton
Posted: Sun Nov 13, 2005 9:55 pm Post subject: |
Yes it does work
http://www.pocketgpsworld.com/apos626btreceiver.php
I had 527mph on my Go300 theres not much interferance at 35000ft :D
You have to get quite close to the window with the GO but it will fix easy enougth. |
Posted: Sun Nov 13, 2005 11:21 pm Post subject: |
Aw
Im £50 down.  _________________ My favourite site of the week ! www.satnavvoices.com |
Stanley_Tweedle Regular Visitor
Posted: Mon Nov 14, 2005 8:18 pm Post subject: |
Yes I did it recently and got 520mph off the coast of Denmark.
It was actually very difficuilt to get a signal even holding it at the window (I guess they use the same glass as renault!) |
adamkodish Occasional Visitor
Posted: Fri Dec 02, 2005 1:43 pm Post subject: Using a TTG 700 in a Boeing 777-200 |
I can verfiy that the TomTom works inside a plane, once you get a GPS lock. I got the best lock about a foot away from the window rather than holding it up to the window. I recorded a speed of 682 mph on a bearing of 46% over Kentucky, whilst flying from Houston to London.
Its best to use the 2D map view when doing this and even then it kept keep zooming in too far. Does anyone know how to keep the map view on TTG zoomed out as far as possible all the time?
The speed readout was consistent with the in-flight airshow video they had on the plane. The in-flight magazine (on Continental) said its ok to use a GPS device (at the same times that they allow you to use a laptop) |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Fri Dec 02, 2005 1:55 pm Post subject: Re: Using a TTG 700 in a Boeing 777-200 |
adamkodish wrote: | Does anyone know how to keep the map view on TTG zoomed out as far as possible all the time?
Yup, just go to More > Browse Map and it will show your GPS position at whatever zoom you like. You might have to keep choosing Options > Centre on Map to keep your position in the middle of the screen
I quite often use this feature when I'm a passenger in a car.. and bored :P |
tweety Occasional Visitor
Posted: Fri Dec 02, 2005 6:38 pm Post subject: |
once upon a time.....not too long ago. the onboard systems on a jet failet and a customer/passenger GPS was used to land the plane. I was told it was a Garmin GPSIII.
I've used mine on nearly every plane for years except some airlines still don't allow there use. However ask the staff to ask the captain and the answer is usually yes.....even during takeoff and landing with some pilots ! After all the GARMIN units were designed for use in aircraft. The route plotting on the GARMIN III allows a direct straight line to be drawn from were you are now to somewhere else....if flying to south america for example you can see how far out the way they go from the optimum flight path following standard routes that you can research before you go. Its like going to Seoul via southern mongolia rather than through russia and near to the north pole, which is the more direct route. Around 500miles longer in fact via the southern path. Politics and Safety i would guess. |
robinb Occasional Visitor
Posted: Fri Dec 02, 2005 6:56 pm Post subject: |
i tried last week on tt700, i was in the window seat over wing & could not get signal lock. after 30 min or so i gave up. flying from spain to uk |
lbendlin Pocket GPS Staff
Posted: Fri Dec 02, 2005 8:37 pm Post subject: |
It helps if the unit has a fix before you enter the plane. It's very difficult to load the base data through the tinted glass. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Fri Dec 02, 2005 8:57 pm Post subject: |
Exactly the problem....at high speeds it take ages. the new chips are better though but not great. Best be is to get a fix in the airport and then again quickly before taking off. Without the staff catching you as sometime this causes a bit of a argument. (which i always win via el-capitain)
lbendlin wrote: | It helps if the unit has a fix before you enter the plane. It's very difficult to load the base data through the tinted glass. |
Posted: Sat Dec 03, 2005 2:51 am Post subject: |
IIR It dident take to long to get a fix on my flight with the Go300 probably just that cheap Easyjet Glass  |
