ally323 Occasional Visitor
Posted: Wed Nov 23, 2005 7:33 pm Post subject: Newbie questions... |
Hi all, newbie here, I have just been given tom tom 300 as a present, so i apologise if these questions have already been asked before.
How much space will the cd rom take up on a pc?
Which is the best site to get safety camera downloads?
Thanks in advance!! ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Wed Nov 23, 2005 7:59 pm Post subject: Re: Newbie questions... |
ally323 wrote: | How much space will the cd rom take up on a pc?
Which is the best site to get safety camera downloads? |
TomTom doesn't use any space on the Hard Drive if that's what you meant, only in any Backup's you do and the best Safety Camera Database can be found here - http://www.pocketgpsworld.com/uksafetycameras.php
Note: Do Backup first. _________________ Richard
Andy_P Pocket GPS Moderator
Posted: Wed Nov 23, 2005 8:33 pm Post subject: |
To expand on that: there is NO backup at the moment of your vital maps data - it is ONLY on the card, not on the CD supplied with the Go. So do a backup now, before you do ANYTHING (like adding the free speed cameras).
The CD allows you to back up your personal settings, and *may* (depending on which version of it you have) allow you to back-up the entire memory card.
Many people here started out when the CD utility DIDN'T back up everything, so have had to do it manually by connecting the Go to a PC via the USB lead, letting Windows see it as a new drive and then copying the entire contents of the card to a new folder on their PC's hard disk.
Its probably still the easiest method, if you are happy with copying and pasting files generally. |
Posted: Thu Nov 24, 2005 8:31 pm Post subject: |
Cheers for the replies folks, it was just that i didn't know what the cd was for as it doesn't really say in the instructions, you know, like with my mobile eg, i had to load the cd rom for it in order for it to copy music, pics etc, basically to run the software innit?
Thanks for the link too! I will give it a look.
I actually had to send the thing back last night too, after using it for half day, there was a small mark on the screen to begin with, like it had been knocked or something, this got worse as the day went on, rainbow effect spreading over it when touching it, (LCD leaking??)
has anyone else had this trouble? ![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) |
Posted: Tue Nov 29, 2005 3:48 pm Post subject: |
Hi again,
I downloaded the database ok to the PC, then tried to copy it into the ttgo 300 via usb. It said the disc was full, i take it this is the card?
I then read that you must copy the files into the "Great Britain" section, again it said full, & to delete some files.
I deleted the "faces.dat" file from there to make space, should i have done this? i haven't a clue which i should delete to make space?? I have made a back up so can easily restore it but it leaves no room for the camera database?? 8O
I then copied the datbase into this folder, but it does not come up in POI menu. Is it only the .ov2 files & .bpm files that should be copied over, leaving out all the other files such as .asc, .csv, f.wav, temp.wav, .wav, txt documents, .xls sheets?
Many thanks for all your patience!! :D |
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Tue Nov 29, 2005 4:13 pm Post subject: |
faces.dat is a key part of the map info!! Put it back.
If oyu need more room on the card. Remove the foreign voices you don't need. This can be done via the setup.exe on the CD (or upgrade). Or you can just trash the appropriate data**.chk and matching .vif files.
engm.vif and engf.vif with data04.chk and data05.chk are the English male and female voices. The rest can go. EXCEPT the main data.chk itself which carries the system sounds. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Tue Nov 29, 2005 4:46 pm Post subject: |
Ta very much, you are right, it mucked up the map a wee bit so I re installed it. CD ROM is in the box & can't get to it just now cos of decorating !
Much appreciated. :D |
Posted: Thu Dec 01, 2005 6:22 pm Post subject: |
Well, I finally managed to make space for the cameras, (I think) by deleting some foreign voices thanks to sgould for that info :D , still don't know the right numbers for all the chk files etc as I haven't yet used the CD ROM.
I unzipped the database, found the folder named .0v2 bmp files, opened it & found about 10 or so files? Trying to remember this as I am now offshore. So i copied them into the "Great Britain" folder on the ttgo, safely removed it form the PC, switched it back on & "No Maps Found" on the display. It kept rebooting over & over, & saying no maps found. So i removed the cameras again, put everything back to original staus & it works ok again, minus the cameras ofcourse.
What have i or haven't i done?? A friend who has one suggested it may be that i have not yet registered it online wityh the number supplied on the card, & then this activates it? Could this be the problem?
Can't get to it for another two weeks now. ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Thu Dec 01, 2005 7:39 pm Post subject: |
The GO comes pre-activated, it's works straight away. _________________ TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Posted: Fri Dec 02, 2005 8:46 am Post subject: |
Ok so, any idea why it says no maps found when i copy in the ov2 & bmp files?? Is it the the correct files i have copied? There were 12 of them in the 0v2 bmp folder once i unzipped the database.
Really appreciate all the help. ![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) |
Posted: Fri Dec 02, 2005 11:48 am Post subject: |
Does nobody read other posts? :D
I must have copied and pasted this list about five times in the last couple of days....
Here's what you need if you want the speed-zoned set.
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_40.ov2
pocketgps_uk_gatso_50.ov2
pocketgps_uk_gatso_60.ov2
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_gatso_var.ov2
pocketgps_uk_mobile_20.ov2
pocketgps_uk_mobile_30.ov2
pocketgps_uk_mobile_40.ov2
pocketgps_uk_mobile_50.ov2
pocketgps_uk_mobile_60.ov2
pocketgps_uk_mobile_70.ov2
pocketgps_uk_mobile_tba.ov2
pocketgps_uk_temp.ov2
pocketgps_uk_specs.ov2
pocketgps_uk_redlight.ov2
(plus their matching .bmp icon files)
Put them individually (i.e. not in a folder) into your maps folder. |
