Gatesy Occasional Visitor
Joined: Nov 04, 2005 Posts: 24 Location: Dartford, Kent, England
Posted: Wed Nov 30, 2005 9:31 pm Post subject: Full postcodes TTN5.210 |
A friend of mine has a HP Ipaq 2210. He let the battery run down & lost the data. I helped him re-install from the CD's & also updated from TTN5.000 to TTN5.210. However, both before & after the update it would only do a postcode search up to 5 digits.
On the SD card, there are 2 folders, "Great_Britain-Map" & "Zip". I am led to understand that "Zip" is the folder that contains the info for postcodes. I have tried again from the CD but still no joy. The folder "Zip" contains a file called "Great_Britain.Postal" which is 8.41Mb.
Anyone have any ideas what is needed to enable full 7 digit UK postcode search on this as i am stumped.
HELP! _________________ Best wishes.
Gatesy. |
kartracer Frequent Visitor
Joined: 26/03/2003 20:15:33 Posts: 502 Location: United Kingdom
Posted: Wed Nov 30, 2005 9:40 pm Post subject: |
There should also be a folder called TOMTOM on the SD card. It can be empty. _________________ Kam |
Posted: Wed Nov 30, 2005 10:10 pm Post subject: |
No folder on the card other than the one's previously mentioned. There is a file on the PDA called "TomTom". Unfortunately, when I started this topic, I was at my friend's house but i am now at my house & do not have the PDA with me at present. Going from memory though, I believe the folder "TomTom" had files in it, but I don't recall what they were called. _________________ Best wishes.
Gatesy. |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Wed Nov 30, 2005 10:11 pm Post subject: |
You can make the folder yourself. _________________ Tim |
Posted: Wed Nov 30, 2005 10:14 pm Post subject: |
So I have to create a folder called "TomTom" & put it onto the SD card, leaving the folder "TomTom" empty? _________________ Best wishes.
Gatesy. |
Oldboy Pocket GPS Moderator
Posted: Wed Nov 30, 2005 10:28 pm Post subject: |
Gatesy wrote: | So I have to create a folder called "TomTom" & put it onto the SD card, leaving the folder "TomTom" empty? | That's correct. Put it in the Root of the SD card, at the same level as the Zip Folder. _________________ Richard
Yes that is all that is required a TomTom folder in the root of the SD card and should all work fine - Mike
Edit - Sorry Richard - double post with the same info -Mike |
Posted: Wed Nov 30, 2005 11:54 pm Post subject: |
I shall give that a go. Thanks guys. _________________ Best wishes.
Gatesy. |
richard_ha Occasional Visitor
Posted: Thu Dec 01, 2005 1:01 am Post subject: |
the ZIP folder have to be in "My Documents" on the device...
"My Device\My Documents\ZIP"
Like that. |
alix776 Pocket GPS Moderator
Posted: Thu Dec 01, 2005 10:25 am Post subject: |
with thw lastest update the empty tomtom is included just selct to install this as well as the update and postcodes should work fine _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
gigino Occasional Visitor
Posted: Fri Dec 02, 2005 8:01 pm Post subject: |
I'm having the same problem with the postcode I only get for example SW18 (London)
If I put SW183DA I only get SW18 (London).
I've done evrything I've got a folder in the root of the SD card called TomTom and any Called Zip, but still I cannot get the 7 digital postcode.
I've look in the CD but they is only Postcode for London and One for the Netherland.
I've ask this question befor but I got a reply say not to ask for crack I'm a full register user of Tom Tom and I do not belive in crack versions.
Please somebody help.
I have the Tom Tom Navigator Mobile 5 and on that it gives me the full 7 digital postcode.
Regards
Gigino |
Posted: Fri Dec 02, 2005 9:01 pm Post subject: |
rforgot to say in previous message the zip folder has 2 file 1 called Great_Britain.postal and setup.dat.
Is this correct because I've deleted the zip file from my pda and the tomtom folder and I still get a postcode like this SW18 (London).
So to me it looks like that it is not reading the files in the zip folder.
Am I right in thing this.
I've upgraded to the 5.2 version but it has installed it in the main memory I what let me choose where to install it. I would like to install it in the storage card.
I could copy it to the storage card and make new shorthcut but how can I get the shortcut on the today screen to look in the stoarge card.
Regards
Gigino |
SHADOW Occasional Visitor
Posted: Sun Dec 04, 2005 4:48 am Post subject: |
gigino wrote: | Hi
Regards
Gigino | ..hi gigino...locate the file that is named "zip" and drag it into the "my documents" folder on your device using activesync..this will give you full 7 digit postcode.. _________________ COMPAQ 3970-TOMTOM V5.210-TOMTOM BLUETOOTH RECEIVER |
Posted: Sun Dec 04, 2005 7:39 am Post subject: |
The above will work, and is what is posted on the TomTom web site FAQ's but it consumes valuable memory, if you follow the advice to create the empty folder (or update to 5,2 as the installer will create the empty folder) then you will get the more efficiant set-up - Mike |
MAB Occasional Visitor
Posted: Mon Dec 05, 2005 5:35 pm Post subject: |
I have just encountered the same problem, trying to get FULL post codes to register. What you need to do is touch on "Navigate to" then go to next page which shows the icon "PostCode". This will give you the option to input the full post code.[[/quote] |
