Paul_D_W Occasional Visitor
Posted: Wed Nov 30, 2005 10:54 pm Post subject: Incar Power |
I've rently bought a ttg300 and am powering it using the psp charger ! Reason being that the cigarette lighter's cablind in my car has been totally removed. Does anyone have any idea's at all, if i take it to a garage, how much it would cost to have it rewired ? |
sgould Frequent Visitor
Posted: Wed Nov 30, 2005 11:56 pm Post subject: |
Best way is to re-install the cig light socket (or another one behind the dash). You need one to use the charger. The charger lead cannot be cut as the plug includes a voltage regulator which drops the 12 volts of the car to 5 volts for the GO.
If you put 12 volts into the GO it starts to smoke. And then it doesn't work _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Gmonkey Frequent Visitor
Joined: Oct 17, 2005 Posts: 390 Location: Washington DC
Posted: Thu Dec 01, 2005 12:02 am Post subject: |
the psp charger doesnt have the same input does it??? I thought it was smmaller |
Andy_P Pocket GPS Moderator
Posted: Thu Dec 01, 2005 4:10 am Post subject: |
sgould wrote: |
If you put 12 volts into the GO it starts to smoke. And then it doesn't work |
All electronic equipment comes from the manufacturer with the correct amount of smoke pre-packed inside for normal functioning. If you let that smoke out, it won't work any more.
:D |
AdamSmasher Occasional Visitor
Posted: Thu Dec 01, 2005 7:16 pm Post subject: |
Yes, very be careful when using a different adapter. I've done stuff like that before and it works for a while, until that extra .5 volts melts the wires or something worse. |
Posted: Fri Dec 02, 2005 10:53 pm Post subject: |
Gmonkey wrote: | the psp charger doesnt have the same input does it??? I thought it was smmaller |
Works for me, Isn't as snug as it could be but it works once plugged in and left alone. |
