PONDEROUS Frequent Visitor
![](modules/Forums/images/avatars/7435662394370caccef1f8.jpg)
Joined: Aug 25, 2004 Posts: 634 Location: Lincolnshire, England
Posted: Wed Nov 30, 2005 11:50 am Post subject: RUNNING TT 5 AND ANOTHER NAVIGATOR ON SAME PPC |
I have been experimenting with TomTom 5 and Copilot 6 running on a single Dell Axim X50v under the 2003 OS, and they seem to coexist quite happily. I run them completely separately, and don't attempt to run either in the background.
One thing that I do have to do is to run TT 5 from the CF card and CP 6 from the SD card. When I installed both on the I Gig SD , which had plenty of space to spare, TT 5 would run once only then I'd get an error meaage to the effect that a component of the TT 5 could not be found.
I wonder if anyone else has experienced anything like this, or has any explanation? _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
lbendlin Pocket GPS Staff
Posted: Wed Nov 30, 2005 4:39 pm Post subject: |
this is a timing issue. you need to give the PocketPC about five seconds after wakeup before you start anything from SD card. Apart from that there's no reason for the apps to be on separate cards. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed Nov 30, 2005 4:40 pm Post subject: |
Many thanks, Lutz, for the information. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
Posted: Wed Nov 30, 2005 4:48 pm Post subject: |
Thanks for your note about double posting on the simnlar thread I created on the Copilot forum.
I had thought it reasonable to post on both forums as the topic was relevant to both groups of users. Of course, I won't do similar in the future if, on reflection, you insist. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
Bazzer Regular Visitor
![](modules/Forums/images/avatars/gallery/garmin.jpg)
Posted: Wed Nov 30, 2005 5:08 pm Post subject: |
Yes, I just noticed that the thread on the CoPilot forum had been locked and thought that it was a very harsh stance by the moderators.
I thought that it perfectly acceptable to post on both forums as they are valid questions for both systems.
How many people actually use both CP & TT and would actually notice (or even care one iota) if it had been posted twice.
Lighten up you lot.
Baz
:x _________________ Garmin DriveSmart 61 LMT-D
TomTom Go 50 - Going in the BIN
TomTom Go 730 (RIP)
Garmin Montana 650
Garmin Oregon 45oT
Garmin Edge 1000
Tracklogs Digital Mapping |
Posted: Wed Nov 30, 2005 5:19 pm Post subject: |
Sorry to drag this one on, Lutz but waiting for a period has not solved the problem. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
Posted: Wed Nov 30, 2005 5:24 pm Post subject: |
I thought it worth adding that TomTom Navigator is greyed out in the list of recently-run programmes.
Also, I tested the SD card yesterday, by writing to it until full and copying the whole card back onto hard disk. It still appears OK when I put it in a card reader and look under Properties. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
Posted: Wed Nov 30, 2005 5:42 pm Post subject: |
PONDEROUS wrote: | I thought it worth adding that TomTom Navigator is greyed out in the list of recently-run programmes. |
Greyed out? What operating system is that?
If that happens, is just TomTom unable to start or are other programs on that SD card affected as well ? _________________ Lutz
Posted: Wed Nov 30, 2005 5:53 pm Post subject: |
Sorry, Lutz. I don't think my terminology was too clear. What I meant was that the red TomTom hands logo was replaced in the list by a blank box. It is the 2003 OS.
I think I'm getting somewhere now. There are actually two copies of the TT 5 startup logo under Programs. Presumably, one is for the CF and the other for the SD. The one called from the Today screen must be the CF card, which I removed to see if it would run from the SD card. I suppose that would explain why I got the failure.
I'll re-install so there's only one installation and try again.
Thanks. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
Posted: Wed Nov 30, 2005 6:29 pm Post subject: |
Having re-installed and waited the 5 seconds as advised, I've finally got there.
Thanks again for the advice. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Wed Nov 30, 2005 7:08 pm Post subject: |
On the point of double posting, such postings usually both get answers, and we feel that it's advantageous to have all the answers in one thread. Duplicating the answers takes up valuable space and splits the answers up. _________________ Tim |
Posted: Wed Nov 30, 2005 8:46 pm Post subject: |
Tim Buxton wrote:
Quote: | ... it's advantageous to have all the answers in one thread. |
I agree, Tim but, with respect, that addresses only part of the matter in question. Had Lutz put in a link to the TomTom forum version of my question and said something like "any answers to here", that would have followed your logic perfectly. However, the thread was merely locked and thereby became a dead end as far as any responses were concerned. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
Posted: Wed Nov 30, 2005 9:09 pm Post subject: |
I have appended Lutz's reply with a link to this thread. _________________ Tim |
Posted: Wed Nov 30, 2005 9:26 pm Post subject: |
Thanks, Tim. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
neil01 Frequent Visitor
![](modules/Forums/images/avatars/gallery/118.gif)
Posted: Wed Nov 30, 2005 9:38 pm Post subject: |
Pragmatic common sense prevails! |
