Pocket GPS World :: View topic - TomTom 5 PocketPC v5.21 and PalmPC v5.201 Updates Released
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
NickG
PostPosted: Tue Nov 29, 2005 1:18 pm    Post subject: Reply with quote
Out of interest, why do so many people prefer the "landscape" mode? Sat nav is one of the very few applications that screams to me that it needs portrait. The map is "track up" in Garmin speak and therefore in portrait you get to see more of where you're going and receive more visual "notice" of turns junctions, roundabouts, cameras etc, if the device is in portrait mode. For instance, as I drive up to a roundabout, I like to visually see which exit i'm going to need as often tomtom's voice directions are confusing or simply incorrect (there's a roundabout near me where the screen is correct but the voice guide says "take the 4th exit, when there are only 4 exits - meaning I would make a U-turn if I actually took notice of the voice instructions!).
In landscape, most of the detail is to the sides - which I would have thought is irrelevant for the 99% of the time you're not turning.
joni
PostPosted: Tue Nov 29, 2005 1:38 pm    Post subject: Reply with quote
If windscreen mounted, landscape obscures less vision. The route details are also much easier to read.
PostPosted: Tue Nov 29, 2005 1:56 pm    Post subject: Reply with quote
Actually there has been some research on this subject. Whilst 'Portrait' is technically a superior format allowing more of the route ahead to be displayed, the reason we prefer 'Landscape' is because that is how our eyes work with more vision laterally i.e. the human eyes operate in Landscape format and hence we tend to prefer that layout.
andy-c1
PostPosted: Tue Nov 29, 2005 2:07 pm    Post subject: Reply with quote
absolutley great i wasn't expecting this till i came back from holiday next year
TomTom 5001
gpssparky
PostPosted: Tue Nov 29, 2005 2:12 pm    Post subject: Re: Customised warning sounds, will they still work ? Reply with quote
Willr2d2 wrote:
Will the customised POI warning sounds still work if I install the Navigator 5.2 update on my PPC ?
If they don't should I use the same data.chk file after the update ?
Just installed and custom poi warnings were overwriteen. Back to bells and whistles!
Confused
Everywhere and nowhere
Tomtom Go 540 Live - That's it.
Privateer
PostPosted: Tue Nov 29, 2005 2:27 pm    Post subject: Reply with quote
I prefer to use portrait mode. As NickG says, you are running an application with track/head up and thus get more advanced warning with portrait than landscape. In fact I can’t stand landscape mode. I obviously don’t comply with the research findings.
I can understand joni’s statement about landscape mode obscuring less vision if you have a windscreen mount. However I use Brodit Pro Clip mounts, so that my PDA is level with the dashboard. I have recently tried a new (to me) windscreen mount for my iPAQ hx4700, which I always had in portrait mode, however I have a Land Rover which has a large front windscreen hence I have no loss of forward vision.
To throw even more things into the mix, I now always run TomTom Navigator 5 in 2D mode as opposed to 3D mode. I find it much easier to accurately check the position of cameras in our database.
I think that it’s a fair assumption that everybody’s requirements are different and that as long as their set-up works for them, then that is all that matters! Thumbs Up
Robert.
Garmin Camper 770 LMT-D
MikeProcter
PostPosted: Tue Nov 29, 2005 2:28 pm    Post subject: Reply with quote
Has anybody noticed that Tom Tom no longer support the PalmOne Treo 650 with this latest release?
I have installed the latest update 5.201 & it seems to be working so far.
Skoda Columbus and for emergencies: TomTom + iPhone 4 & TomTom car kit
NickG
PostPosted: Tue Nov 29, 2005 2:36 pm    Post subject: Reply with quote
I think that theory is only really true when the display you are looking at is quite big (eg a TV or a cinema screen) so that you're using your peripheral vision. When the screen is tiny, you would think that the only thing that matters is seeing more of the information you need to see, which in the case of sat-nav, is the road ahead and upcoming junctions or POIs. Imagine if you exaggerated it so that the display was cinema format - it would be useless.
NickG
PostPosted: Tue Nov 29, 2005 2:41 pm    Post subject: Reply with quote
Privateer wrote:
I prefer to use portrait mode. I obviously don’t comply with the research findings.
I'm pretty sure the "research findings" were not testing tiny screens when used with sat-nav. For watching TV or films, 16:9 widescreen or even cinema format is ideal.
Don't forget that the bit of your eye which is actually capable of seeing high-detail (such as text or a map) is CIRCULAR and is a tiny fraction of the total area of your retina. Therefore the optimal screen shape for high detail is be circular or square... This is according to my HCI lecturer that is - I'm not just making it up Smile
NickG
PostPosted: Tue Nov 29, 2005 2:49 pm    Post subject: Reply with quote
I *REALLY* wish they would merge Tomtom Navigator 5 and Tomtom Mobile 5. They are becoming more and more alike and TTN5 now works on several "phones".
It's really annoying that you have to have two licenses if you want to use both products. I'm pretty sure there is no longer a technical or marketing reason to seperate the two.
Perhaps some of the PGPSW crew who have more influence could try to pursuade TT to merge the two products so that it simply installs the correct version when it detects your device. (obviously more than one activation would be required, but I don't see why that should be a problem as if I've paid for a product, it should be up to me how many devices I install it on within reason).
Nick....
MikeProcter
PostPosted: Tue Nov 29, 2005 2:56 pm    Post subject: Reply with quote
Nick....
You can currently have more than one device activated - I have ttn 5.xx on both my Treo 650 & T3 Palms', as I had problems with my Treo when I first started using it, so they activated my T3 for me. Now they don't support the Treo anymore Crying or Very sad
You can change every 6 months & within the first 7 or 14 days I believe.
RobT
PostPosted: Tue Nov 29, 2005 3:23 pm    Post subject: Reply with quote
I actually think you can see as far ahead in landscape, it seems to zoom out slightly more. Could be my imagination though ;)
Horses for courses though!
PostPosted: Tue Nov 29, 2005 3:31 pm    Post subject: Re: Customised warning sounds, will they still work ? Reply with quote
Confused
We have an updated data.chk available on the www.pocketgpsworld.com/tomtom-poi-alerts.php page
MikeProcter
PostPosted: Tue Nov 29, 2005 3:47 pm    Post subject: Reply with quote
I can see no more information or map on the Palm T3 in landscape or portrait mode, or even when it isn't extended. My Treo 650 shows the same information, but an a smaller screen.
The landscape screen just makes everything wider, portrait taller & the Treo, smaller!
NickG
PostPosted: Tue Nov 29, 2005 3:49 pm    Post subject: Reply with quote
It seems to zoom out to accommodate it... but as it's zooming out, you are seeing less information. The resolution of the bit you need to see is lower because it is showing you more stuff at the sides that you don't need to see.
Page 3 of 9
22.062 (12 Jun 24)
