Pocket GPS World :: View topic - XDA IIi and TomTom
XDA IIi and TomTom
AdamPridmore
PostPosted: Mon Nov 28, 2005 6:36 pm    Post subject: XDA IIi and TomTom Reply with quote
I have been using an XDA IIi with the latest firm ware (1.11.162) and I somtimes get the problem where when the XDA has been suspended for a while (say >1 hour) when the device resumes TomTom (5.1) cannot immediatly locate the maps (i.e. if I zoom out i cannot redraw the current map, and I cannot do any routing).
If I change map from withing TomTom back to GB, or exit and relaunch TomTom it is fine. I'm guessing that when the device resumes the SD card isn't imediatly ready and TomTom get confused.
I've tried this with a couple of different SD cards and still get the same problem.
Can anyone help with this? Is there anything I can do to stop this happening? Have you had the same problems?
TIA
Adam
alix776
PostPosted: Mon Nov 28, 2005 9:16 pm    Post subject: Reply with quote
do you stil have o2 acitve on the device if so get rid of it also it seams the best thing for the xda2i is to get the fastest card you can find ie x80
device Lumia 950 xl
AdamPridmore
PostPosted: Tue Nov 29, 2005 11:44 am    Post subject: Reply with quote
I've tried disabling o2 active and with 3 different SD cards including one provided by TomTom and I still get the same problem.
Is there anything else you can suggest?
Ta
Adam
alix776
PostPosted: Tue Nov 29, 2005 12:21 pm    Post subject: Reply with quote
when you say you suspend the device do you mean turn off the witht the power button whilst navigator is still running
if this is the the case then exit tomtom by using the exit application button in the navigator menu fisrt
device Lumia 950 xl
AdamPridmore
PostPosted: Fri Dec 02, 2005 6:54 pm    Post subject: Reply with quote
I've found that running the lastest TomTom release 5.21 fixes this problem.
22.064 (26 Jun 24)
