paulthetool Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_013.gif)
Joined: Nov 21, 2005 Posts: 45 Location: Clacton on sea, Essex
Posted: Sat Nov 26, 2005 3:44 pm Post subject: Editing POI file ?? |
Hi all,
is it posible to edit EVERY line in a POI file in one go without doing it line by line?
I would like to edit the description of every line in the gatso file
just to leave the speed. IE from GATSO:1518@60 to just 60 ?
this will allow me to show the speed next to the cam icon on the map
without the GATSO:1518@ bit cluttering up the map
Paul
paulyoung04@aol.com |
Pocketgps Lifetime Member
![](modules/Forums/images/avatars/gallery/1_navigon_7110.jpg)
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Sat Nov 26, 2005 8:08 pm Post subject: |
If you load it into Excel then you could remove that column and replace it with whatever you require. |
Posted: Sat Nov 26, 2005 8:23 pm Post subject: Excel |
I know I will be able to remove the whole colum with excel but it will also remove the speed part at the end !
Paul |
Oldboy Pocket GPS Moderator
Posted: Sat Nov 26, 2005 8:29 pm Post subject: |
You could use something like Word to Find & Replace. Don't save it as a .doc file though. _________________ Richard
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Sat Nov 26, 2005 8:30 pm Post subject: |
But then you'd have so many hundred(?) POIs called 30, which might confuse the software somewhat. _________________ Tim |
Posted: Sat Nov 26, 2005 9:26 pm Post subject: |
... and also which one had been removed/changed etc. _________________ Richard
Posted: Sun Nov 27, 2005 4:12 pm Post subject: Re: Excel |
paulthetool wrote: | I know I will be able to remove the whole colum with excel but it will also remove the speed part at the end !
Paul |
You can select via the different menus within Excel what to remove in each column, you can break down each column and split it how you require, so no it does not remove all of the data.
You can put column breaks where ever you require, that's the whole point of Excel. |
Posted: Sun Nov 27, 2005 4:54 pm Post subject: Excel |
I am trying to do this in Excel, but not sure what function to use ? ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
JLee Regular Visitor
Joined: Dec 11, 2005 Posts: 139 Location: Barnsley UK
Posted: Thu Dec 29, 2005 11:02 am Post subject: Re: Excel |
Paul |
Just create a new column next to it and use a formula to leave the speed at the end. This assumes that the original column is A, the new column is B and the speed at the end is 2 characters:
1. Click in cell B1 and type the formula =Right(A1,2) and press enter.
2. Highlight all cells in column B down to row n where n is the last row that is filled in in column A (so if data in column A goes down to A350 highlight cells B1 to B350).
3. From the menu select Edit>Fill>Down.
4. Highlight the whole of column B and Edit>Copy, followed by Edit>Paste Special>Values.
5. That should give you what you want so just delete column A |
