angler Occasional Visitor
Posted: Fri Nov 25, 2005 1:06 pm Post subject: installing POI,s on navman 610 icn. |
After installing I need to change the icon shown on the map.
Can anyone explain how this can be done Please, if at all.
Thanks for any help.
Ken. |
Posted: Fri Nov 25, 2005 5:10 pm Post subject: |
Generally you select the .bmp to be used at the time of transfer of the POI group from PC to iCN. If the POI files on the iCN are stored in internal memory (not storage card) then this will be the only way to do it. _________________ Tim |
Posted: Fri Nov 25, 2005 6:42 pm Post subject: |
Thanks Tim for reply,
This is the problem I did'nt select the bmp when I transferred the files and as a result ended up with one not suitable to the POI.
Do you know if they can be uninstalled from the internal memory and reinstalled with the correct bmp.
Ken. |
Posted: Fri Nov 25, 2005 9:59 pm Post subject: |
Problem solved Thanks.
Removed POI's from Navman and Reinstalled with correct bmp file, everything now working O.K.
Ken. |
