Pocket GPS World :: View topic - searching more than 1 address at a time?
stu3y
PostPosted: Wed Nov 23, 2005 1:28 am    Post subject: searching more than 1 address at a time? Reply with quote
right i use my garmin for delivers, i often get 3-4 deliveries at a time and need to get to each place as fast as i can, sitting at each place putting an address in and hoping its closer than any other address is a bit annoying because sometimes i endup backwards and forwards all over the place when it would have been faster to do them 1 by 1 if you get me,
any way i was having a play around, entered 1 address, then started navigating, then i entered a 2nd address and pressed navigate, is said via point or somthing like that, i clicked yes, is i was to put 4 addresses in and click yes to via point on all of them, will it take me to each closest one?
thanks and sorry if its abit confusing Embarassed
Tubal
PostPosted: Wed Nov 23, 2005 11:38 am    Post subject: Reply with quote
It will if you put the furthest away address in first. If not then it will go to the "vias" first and back to the last address, ie.
London to Edinburgh, via, Birmingham, Manchester and Carlisle will work.
London to Birmingham, via Manchester, Carlisle and Edinburgh would route as follows:
London, Manchester, Carlisle, Edinburgh then Birmingham (never tried so many but I think this is how it works.
JonA
PostPosted: Wed Nov 23, 2005 12:22 pm    Post subject: Reply with quote
The i3 builds up a list called 'recent finds'.
You could go through and find each address separately, then use the recent finds to look them back up again. Then siple navigate to them.
Hope this works!
dougconran
PostPosted: Wed Nov 23, 2005 12:30 pm    Post subject: Reply with quote
Hope this works!
The trouble with that is that you have to do your route planning yourself.
At the end of the day the i3 focuses on one job - getting you from where you are to where you want to go - and is built to a price to reflect that. If you want more than that you will probably need to buy something more exotic and expensive (like the Gun Shoot Out tom tom)
stu3y
PostPosted: Wed Nov 23, 2005 1:18 pm    Post subject: Reply with quote
what about tomtom mobile? will that plan rountes?
i am gettin a new phone tomorrow, the W800i, i think i can put tomtom software on to that?
dougconran
PostPosted: Wed Nov 23, 2005 1:47 pm    Post subject: Reply with quote
I think so but oyu are best off asking the question in one of the tom Tom forums.
gonor
PostPosted: Wed Nov 23, 2005 8:10 pm    Post subject: Reply with quote
it would be handy having this feature, as i too do loads of calls.
however, all mine arrive at 0600, so 10 minutes with a brew and ye olde a-z and some writing gives me a good route. then its simple, bang 'em in one at a time and hi ho silver..awayyy. :D
JinnanTonnix
PostPosted: Mon Nov 28, 2005 3:23 am    Post subject: Reply with quote
</LURK:OFF>
Try this:
Enter all your calls, but instead of navigating to them, store them as favourites. Call these favourites 1,2,3,etc, so they don't interfere with your 'real' favourites. It doesn't matter what order they are, so long as you remember "if it's just a number, it's just a call"
When you entered them all, go back to the main screen choose "Where To -> My Favourites", and all the favouites are listed in distance order, closest first to your current position. Just work through these - be sure to delete them as you go - and this should, in theory, give you at least some kind of intelligent multi-drop routing. It may not be quite what you need, but at least it'll give you some amusement!
</LURK:ON>[/b]
n4nick
PostPosted: Wed Aug 16, 2006 8:17 pm    Post subject: Reply with quote
Guys
Is it possible (and if so how) to have my favourites displayed in alphabetical order rather than by distance from current location?
Thank you - Nick
bumpkin
PostPosted: Thu Aug 17, 2006 2:00 pm    Post subject: Reply with quote
Although be warned that the distance that they are sorted by is approximate and, AFAIK, straight as the crow flies. Not too bad if you're doing multi-drop over a wide rural or inter-city/town area but for work based in a city centre (for example) with one ways, rivers, railway lines etc. that mean a drop a mile away might in fact be 3 miles away will mean that the suggestion might not work too effectively in practice.
A higher spec unit will enable you to enter all drops and then sort a route in the most efficient manner.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
22.055 (29 May 24)
