Pocket GPS World :: View topic - How to use Contacts Navigation on TTN5.0 and 5.1?
leonardo1
PostPosted: Tue Nov 22, 2005 12:03 pm    Post subject: How to use Contacts Navigation on TTN5.0 and 5.1? Reply with quote
I just got TTN5 for my Dell Axim50v Pocket PC (and upgraded to 5.1) and wanted to know how to use Contacts navigation. This is one of the main reasons why I bought TTN5 but just can't seem to be able to figure out how it is linked to the Contacts database on my PPC.
When I tap on the Navigate to... icon, there's no option to select Contacts database. Help!!
When I select Start-Settings-Remove Programs I can see that TomTom Contacts Navigation application is installed, along with TomTom Today, TomTom Navigator and TomTom ~Bluetooth Support.
Is this something so obvious that no manual has written about it and no one has a cause to complain except me? Please help. This is driving me NUTS!.
Len
TomTom Navigator 5.10 on Dell Axim 50v
TomTom bluetooth GPS
Sandisk 1Gb CF, TomTom 128Mb SD card
TomTom powered cradle
peterc10
PostPosted: Wed Nov 23, 2005 11:42 am    Post subject: Reply with quote
Border_Collie wrote:
You may find some addresses do not work if you have sync'd with Outlook/Express and downloaded from your desktop. I've had a few I've had to adjust on my PDA to get them to work which in turn updates them on my desktop next time I sync..
The tip for using Addresses from Outlook is not to write directly in the address box of the "new contact" screen in Outlook. Instead click on the "address" button next to the box. This will prompt you for Street City Post Code etc and fill them in. That way it is more likely that TT will recognise the difference between the street and the city for example. The frustrating thing is that it does not appaear to use the post code at for this function.
leonardo1
PostPosted: Wed Nov 23, 2005 12:14 pm    Post subject: another problem Reply with quote
Thanks guys,
I managed to locate a few places on TTN5 directly from Contacts but like you said, it failed to locate quite a few of them, simply because the formatting is not quite right.
Even if I follow the tip from peterc10, some addresses just won't work, e.g.
12 Augustine Court
Reading Road
Farnborough
Hampshire
GU12 3ER
where "12 Augustine Court, Reading Road" go into the Street field, and the rest to City, State/Province, Zip/Postal code fields.
The only way to get it to work is to simply put Reading Road in the address field, but then I wouldn't want to amend the full address in Contacts just so TomTom could pick it up.
Other address like:
120 Fulham Palace Road
London
W2 3OP
works fine without problems.
So, still not quite a polished product, this TomTom Nav 5.1. If only it uses the Postcode instead/as well as the street name, it might be able to locate the address.
soweezy
PostPosted: Thu Nov 24, 2005 11:52 am    Post subject: Re: another problem Reply with quote
it still has problems even with post codes
I've tried navigating to a number of post codes only to find they're showing in a completely different area, not just street, in TT5.1 than the position Yell shows them in... Yell showing the correct street name too where as TT5.1 wasn't even close, one was miles out...
SW
Garmin Zumo 390LM
peterc10
PostPosted: Thu Nov 24, 2005 4:49 pm    Post subject: Reply with quote
I've read elsewhere that problems can arise, when using the full postcode feature if.....
1. Using Navigate to Address, instead of Postcode.
2. Leaving a gap e.g. AB1 CD2 instead of entering AB1CD2.
If you go to"Address" in Navigate to it will only accept 5 figure post codes. To get the full 7 figure you need to choose "Post code" rather than address.
Morris
PostPosted: Thu Nov 24, 2005 10:44 pm    Post subject: no navigate to in contacts Reply with quote
I just cant find a navigate to option in contacts, it was there in my previous version of TT but not in TT5, I'm using a ipaq 3970.
Can anyone help please/
Morris
Grzzzzz Mr. Green
peterc10
PostPosted: Fri Nov 25, 2005 1:00 am    Post subject: Re: no navigate to in contacts Reply with quote
Morris
Grzzzzz Mr. Green
As said before the only way I find it is by pulling up the list of contacts then holding the stylus on the one I want for a while. that brings up a pop up menu which includes the option. AFAIK that was installed automatically when I installed TT5 - it wasn't there before.
Morris
PostPosted: Sat Nov 26, 2005 5:42 pm    Post subject: Re: no navigate to in contacts Reply with quote
I do that, i get the pop up menu but there is no navigate to option, it was there before i upgraded from TT3 to TT5
Morris
Grzzzzz Mr. Green
Vic_Tina
PostPosted: Fri Dec 09, 2005 10:50 pm    Post subject: Reply with quote
Hold on, I'll make that clearer. There are two ways.
1. Touch and Hold pointer on contact name and choose navigate to in drop down window.
or
2. Tap once on the contact, then Tools and Navigate to.
Hi All
Tried changing the way I input addresses and the above but my pop up only gives me ......
Send Email
Beam Contact
Delete Contact
Anything else I can try?
Not that technical Laughing Out Loud
Mio 168
TomTom 5.10
1GB Kingston SD card
Morris
PostPosted: Sat Dec 10, 2005 5:54 pm    Post subject: Reply with quote
[quote
Hi All
Send Email
Beam Contact
Delete Contact
Anything else I can try?[/quote]
Thats all I get as well.
Morris
Grzzzz Mr. Green
