Pocket GPS World :: View topic - Opted for Mio 168 but whats the Baud rate
daveyevs
PostPosted: Sun Nov 20, 2005 3:31 pm    Post subject: Opted for Mio 168 but whats the Baud rate Reply with quote
Posted earlier.
Opted for the mio 168 with smart st software.
It is asking for the com port and baud rate.
What do I input.
It works with com 2 and 4600 but I havent yet been able to get a good fix evan after 1 hour?
Any suggestions?
neil01
PostPosted: Sun Nov 20, 2005 5:44 pm    Post subject: Reply with quote
Assuming that your Baud rate is a typo and you meant 4800, your settings are correct.
Sorry I can't help with the other problem.
PostPosted: Sun Nov 20, 2005 5:48 pm    Post subject: Reply with quote
It should be 4800 on Com 2, make sure the unit is outside and has a clean line of sight to the sky, it should take 15 min (ish) and then it wil work - Mike
daveyevs
PostPosted: Mon Nov 21, 2005 12:11 am    Post subject: Reply with quote
Sorry,
Yes, 4800 on com 2 is what i've used.
I left it on the patio for 20 minutes then drove for 15 mins and got a fix for abot 30 seconds.
Had it for 24 hours. After installing software its worked for 3 mins. I'm in Birmingham UK so would expect a good signal?
daveyevs
PostPosted: Mon Nov 21, 2005 12:36 pm    Post subject: Reply with quote
It says in the bumf that comes with it that it should take 15 minutes from a cold start. Is a cold start where you have clicked the battery off switch on the back.
In fact, how do you turn the unit off. Do you just let it go into standby then turn it back on using the switch on the side.
I discovered to my dismay that if I do click the battery off all f my info is lost includingt the smart st program itself. Is there anyway to stop this happening?
If I still cant get a fix - is it broken?
madtam
PostPosted: Mon Nov 21, 2005 2:22 pm    Post subject: Reply with quote
Shutting down by the switch on the back is not a good idea because it shuts everything down as you have found out. The power off button on the side is the one to use, and it's probably a good idea if you shut down the running applications as well.
I have found that is is best to let it get a fix before heading off anywhere. It takes longer to find itself when it's constantly moving. I don't think mine has ever taken longer than about 5-6 minutes to get a fix when it has good visibility of the skies so you might have a problem. I don't recognise the software you are running so it might be something with this rather than the unit.
maca2
PostPosted: Mon Nov 21, 2005 8:17 pm    Post subject: Reply with quote
I think you might just have a faulty unit but you can check to see if you can get a sat fix by installing the GPS viewer software on the PDA. If you can get a fix using this software then your unit is working fine & it will be your sat nav software that is not working or has the wrong settings.
Cant find a link but will mail you the prog if you send me a mail
ghuntfor6@yahoo.co.uk
I have never waited more than a few mins to get a fix.
22.101 (03 Oct 24)
